Max spring pressure for Crane gold rockers? #850701
11/10/10 06:43 PM
11/10/10 06:43 PM
Renton Wa
topfueldart Offline OP
Renton Wa
Just trying to do a little homework in advance. Considering a set of crane golds on my 318, just wondering what the spring pressure limit is before I'm pushing my luck.
Thanks!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Max spring pressure for Crane gold rockers? [Re: topfueldart] #850702
11/10/10 07:10 PM
11/10/10 07:10 PM
organ
maximum entropy Offline
organ
word on the street is that the quality lately is suspect. i can tell you that i've had the same set in my car for 10+ years and 20,000 miles or so, with a variety of big hydraulic and solid cams, and they're still perfect under the microscope.
Re: Max spring pressure for Crane gold rockers? [Re: maximum entropy] #850703
11/10/10 07:26 PM
11/10/10 07:26 PM
Renton Wa
Renton Wa
The set I'm considering are several (5+) years old, but brand new in box. I realize this is a relative question, but I figured one of the engine builders would say 5 or maybe 600 lbs would be the limit before looking to jesels or similar. I think for a decent hydraulic or small solid roller I'll be looking at 400+ open, and thought I'd see if there were a consensus on the limit of an aluminum body rocker.
Re: Max spring pressure for Crane gold rockers? [Re: topfueldart] #850704
11/10/10 07:48 PM
11/10/10 07:48 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
I run the crane golds with a 230lb seat pressure and 600lb open pressure. I have not had one problem with them yet, i do have my fingers crossed though.
65' Belvedere
496'' Stroker
Indy Heads
Re: Max spring pressure for Crane gold rockers? [Re: topfueldart] #850705
11/10/10 08:17 PM
11/10/10 08:17 PM
mi
dirty magnum Offline
mi
ive run 300 on seat 900 open no problems
Re: Max spring pressure for Crane gold rockers? [Re: dirty magnum] #850706
11/10/10 09:53 PM
11/10/10 09:53 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
here is mine 210 seat lbs. Went to a set of Sharps.
Re: Max spring pressure for Crane gold rockers? [Re: mrpatel] #850707
11/10/10 09:56 PM
11/10/10 09:56 PM
mrpatel Offline
mrpatel  Offline
I did notice that the lube passages on the rockers have very sharp edges and stress risers. Looks like thats where the break may have started from.
Re: Max spring pressure for Crane gold rockers? [Re: topfueldart] #850708
11/11/10 01:13 AM
11/11/10 01:13 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC, at one point Crane stated their Chrysler "gold" rockers weren't intended for more than 600#s open pressure. I never thought they had enough "beef" around the shaft to run that much pressure for long, though.
Re: Max spring pressure for Crane gold rockers? [Re: mrpatel] #850709
11/11/10 02:35 AM
11/11/10 02:35 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Its not the seat lbs thats going to break them. What was your open lbs. mike
Re: Max spring pressure for Crane gold rockers? [Re: Sport440] #850710
11/11/10 10:14 AM
11/11/10 10:14 AM
mrpatel Offline
mrpatel  Offline
Around 600
Re: Max spring pressure for Crane gold rockers? [Re: topfueldart] #850711
11/11/10 07:40 PM
11/11/10 07:40 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I broke one after about 300 passes @ 600# open. I now use RAS 440 max. The RAS rockers are more expensive, but after fixing things, I would have saved money if I had just bit the bullet. Just one more sad cheap rocker story
Re: Max spring pressure for Crane gold rockers? [Re: 66er] #850712
11/11/10 08:20 PM
11/11/10 08:20 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
I would use those 5 year old Golds, but change the adjusters, as the adjusters seem to be junk!!!
Smith Bros makes good ones .
Yes I live in Michigan, so there is still 1 light on
Re: Max spring pressure for Crane gold rockers? [Re: mrpatel] #850713
11/13/10 11:17 PM
11/13/10 11:17 PM
mi
mi
what year is on the rocker? is it a newer one? thanks
Re: Max spring pressure for Crane gold rockers? [Re: dirty magnum] #850714
11/14/10 11:44 AM
11/14/10 11:44 AM
mrpatel Offline
mrpatel  Offline
6-03 is the year
