TTI headers/column shift auto fitment?? Experiences?? #850384
11/10/10 09:50 AM
11/10/10 09:50 AM
Scat City, USA
SleeperBee Offline OP
Scat City, USA
Working on my combination. 1969 Super Bee with column shift automatic. 400 B block with Indy EZ's. Nick wants to run 2" or even 2 1/8" headers. TTI book says no with fitment. Does anyone have any experiences or advice? I'm planning on calling TTI direct. Thanks guys!
Re: TTI headers/column shift auto fitment?? Experiences?? [Re: SleeperBee] #850385
11/10/10 09:52 AM
11/10/10 09:52 AM
an8sec70cuda Offline
Not sure about your combo, but I have a '69 road runner w/ an Indy SR headed 440 in it. I have the TTI 2" to 2 1/8" step headers (for the raised ports) on it and it works w/ the factory column shifter.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: TTI headers/column shift auto fitment?? Experiences?? [Re: SleeperBee] #850386
11/11/10 10:39 AM
11/11/10 10:39 AM
Mid-Michigan
GOREO Offline
GOREO  Offline
Mid-Michigan
I run the factory column shifter on my 68 Dart,440 with E-heads.TTI 2" headers. Works fine after working with the linkage at the shift rod on the trans.Seems that I flipped the rod over.I use a reverse Turbo action valve body also.Maybe not quite the same setup as yor B Body.
Re: TTI headers/column shift auto fitment?? Experiences?? [Re: GOREO] #850387
11/24/10 02:42 PM
11/24/10 02:42 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I run the 1 7/8 headers on my 71 cuda. TTI sold the linkage that goes over the header so I could still use the column shifter.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: TTI headers/column shift auto fitment?? Experiences?? [Re: Prodart440] #850388
11/24/10 03:05 PM
11/24/10 03:05 PM
UK
602heavy Offline
602heavy  Offline
UK
TTI said my 2 1/8th step headers would'nt clear the colum shifter linkage , got them anyway , only clearance issues was the pass side header just touching rear of block , this was on a set of 572-13s , TTI have to cover themselves.
