727 factory stall speeds? #85025
07/06/08 10:25 PM
07/06/08 10:25 PM
Parsons (SouthEast) Kansas
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
anyone know how to tell the stall speeds of factory converters? i have the following good converters: 84 truck 360/727, 79 cop car 360/727 and a 73 360/727 truck. all are good converters. want something around 2000 for my 77 shortbed that is getting a mild 360 in then ext few weeks. i can buy them for around 200$ but if i am only getting a few hundred RPMs of stall, will it be worth it? Can you determine the stall by the diameter? if anyone has a converter around 2000-2400, i would be interested. thanks, JP in KS.
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: 727 factory stall speeds? [Re: funkyjbp] #85026
07/06/08 11:06 PM
07/06/08 11:06 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
converter company we deal with at work tell me a factory converter is no more than 14-1500
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 factory stall speeds? [Re: funkyjbp] #85027
07/07/08 12:48 PM
07/07/08 12:48 PM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
my stock converter was maxed out by the trans shop at 1900
Re: 727 factory stall speeds? [Re: funkyjbp] #85028
07/07/08 04:36 PM
07/07/08 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here is a list of '78 stall speeds, pretty much the same for other years mentioned:
Re: 727 factory stall speeds? [Re: John_Kunkel] #85029
07/08/08 09:54 AM
07/08/08 09:54 AM
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
looks like i will be buying a converter then. it looks like converter diameter is not the determining factor of stall speed. forgive me of my ignorance! thanks, jp in ks.
Re: 727 factory stall speeds? [Re: funkyjbp] #85030
07/08/08 03:16 PM
07/08/08 03:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Converter diameter does have an influence on stall speed, the '78 chart shows only the 10 3/4" because that's the year the 11 3/4" was discontinued.
All other factors being equal the smaller converter will stall higher.
