Re: front brake pulling to right
[Re: car48nut]
#849521
11/09/10 01:10 PM
11/09/10 01:10 PM
Posts: 35 Aurora, CO
Manifold
Aurora, CO
Anyone have any ideas? Thanks
Yep... have the drums turned and put on new hardware (shoes, springs, wheel cylinders). Should be under $100 (Rock Auto prices - Shoes: $20-40, Complete hardware kit: $5-7, Wheel Cylinder: $3-10 each)and it'll all be new and matching parts.
Or, make sure the adjuster system is working on the side of the car which isn't pulling. The pulling could be because one side is working properly and the other side isn't. Ensure the adjuster (with the star wheel) is clean and lubed (I like to use anti-seize). With the drum off and the backing plate completely assembled, use your finger to place tension on the cable which runs from the top of the backing plate down to the arm which turns the star wheel on the adjuster. Make sure when you place tension on it that it is actually turning the star wheel. Also, make sure the correct star wheel is being used (my latest purchase had a passenger adjuster on the driver's side - it won't adjust that way).
Never skimp on brakes!
[Re: Manifold]
#849522
11/09/10 01:30 PM
11/09/10 01:30 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The previous post is complete overkill. It's probably pulling because one of the brake hoses has gotten restricted..They naturally do this as the hoses get old even in non use. Just replace the 2 front brake hoses, and this should fix it. Assuming the parts in the drum are good, and they are adjusted and bled properly.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: car48nut]
#849524
11/09/10 04:55 PM
11/09/10 04:55 PM
RapidRobert
It's pulling hard to the right cause the left side is near dead. open it (left side) up & (1) good basic visual then have a helper press the pedal slightly (just not enough to pop the wheel cyl pistons out if in fact they are not stuck) & you see if things are being activated & go from there
[Re: car48nut]
#849526
11/09/10 05:45 PM
11/09/10 05:45 PM
HemiRick
Memphis
They can but it takes 20 or 30 years after they are new.
[Re: HemiRick]
#849528
11/09/10 06:56 PM
11/09/10 06:56 PM
Manifold
Aurora, CO
Well excuse me.
OP: Good luck getting the problem identified and fixed. After you've eliminated the lines as a source, make sure the adjuster system on the side not pulling is working, then adjust both sides as RapidRobert described. I do my drum adjustments where the drag of the brakes will stop the lightly spinning tire after 1 to 1 1/2 revolutions. So, I like them to drag a little bit more than RapidRobert. It helps take slack out of the brake pedal too.
[Re: Manifold]
#849529
11/09/10 07:18 PM
11/09/10 07:18 PM
RapidRobert
What Manifold said on the (self) adjusters. DR (left) side needs the left hand threaded one(s) & left hand threads have a distictive weird twist to em that you can easily ID just by a quick glance whereas RH threads look (almost) straight
[Re: car48nut]
#849532
11/10/10 09:03 PM
11/10/10 09:03 PM
RapidRobert
I'd undo the line(s) at the M/C & bleed it then bleed the wheels
