360 Magnum bore size. #849478
11/09/10 10:11 AM
11/09/10 10:11 AM
United States
tee-john Offline OP
tee-john  Offline OP
United States
I am looking at getting a 360 Magnum stroker engine that is bored at 4.04. Is this considered to be a lot, or is this bore size ok for a 410 ci street engine? Also, what is a good temperature to run?
Re: 360 Magnum bore size. [Re: tee-john] #849479
11/09/10 10:38 AM
11/09/10 10:38 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Stock bore size is 4.000 So, it is a kit with .040 over bore. It is a lot to go, you need to check the condition/size of the bore in the block you are using before ordering the pistons.
Re: 360 Magnum bore size. [Re: tee-john] #849480
11/09/10 03:43 PM
11/09/10 03:43 PM
MD
ADakotaRTGuy Offline
MD
The magnum's tend to not like a bore that is to big over .030, I would get it sonic checked first. Just the consensus in the Magnum motor users.
