Why did I bend a pushrod? #849283
11/08/10 11:22 PM
11/08/10 11:22 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Today I really needed a stress break so I took the car for a short drive. Drove around a little while and warmed everything up good. Ran it up to about 7200 through 1st and 2nd. Felt something. Backed out heard the miss and clatter. So far I have pulled the rockers. One lash cap is MIA. Pushrod is bent but still in place. Running offset lifters on the intakes and the correct amount of threads on adjusting screws. No galling, adjuster is ok. Good wear pattern on other lash caps. Going to pull the valley cover in the morning to check the lifter. Failure was #1 intake, 440-1s, Harland Sharps, Cam is not real radical. 263/270at.050. .690-lift. #1 cylinder leakdown ok. Springs 230#seat. I am running a smith brothers .083 wall 3/8 pushrod. What should I look for? Is it a pushrod strength issue. I had 2500 miles on it before but always shifted at 6800, this is the first at 7200.
Re: Why did I bend a pushrod? [Re: galen] #849284
11/08/10 11:28 PM
11/08/10 11:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Could the lash cap have come dislodged and cuased a piston to valve issue? Sorry to hear about the damage! Kind of makes a stress reliever go the wrong way.
68 Barracuda Formula S 340
Re: Why did I bend a pushrod? [Re: Bad340fish] #849285
11/08/10 11:40 PM
11/08/10 11:40 PM
UK
602heavy Offline
602heavy  Offline
UK
Not saying it's you're problem but never had much luck using .083" pushrods in an RB when exceeding 600lb spring pressures , those .145" walls are belt & braces.
Maybe go find another stress reliever. , just kidding.
Re: Why did I bend a pushrod? [Re: 602heavy] #849286
11/09/10 12:01 PM
11/09/10 12:01 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
same here,i use .120" wall mantons.i have similar spring pressures.
maybee the lash cap broke. i've had it happen to me. it sucks when that tool steel bounces around in the motor. find that cap ,if you can.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Why did I bend a pushrod? [Re: galen] #849287
11/09/10 01:49 PM
11/09/10 01:49 PM
I had a Smith Bros 3/8 .083 wall heat treated pushrod break in two pieces during a dyno test at 5600 RPM, it knock the top of the roller lifter off, bent the pushrod beside it and ended up dropping into the lifter bore gauging it and the cam lobe I had Smith Bros custom make them, told them all about the motor specs, spring pressures, intended RPM and so on I help some other local racers that own a dyno, they had one of there Smith Bros pushrod break the top off of one during a dyno test also I replace my Smith Bros with a set of seies 3 Manton .120 wall that Terry Manton recommended and that motor made 8 more HP at 300 RPM higher during the next dyno test, A,B,A after fixing the motor Smith Bros did replace the two bad ones free but didn't offer any other help on replacing or fixing the bushing, lifters and camshaft ( I didn't ask them to either )
Re: Why did I bend a pushrod? [Re: galen] #849288
11/09/10 03:58 PM
11/09/10 03:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea I have bent a couple and am going to a .120 wall next year for my roller cam.
My last one went sitting idling in tech line last TT (for me) day and what a racket!! Made enough noise to be a kicked rod!
In with a spare and off for some TT fun.
Usually intakes too with that big offset!
Re: Why did I bend a pushrod? [Re: Dodgem] #849289
11/09/10 04:37 PM
11/09/10 04:37 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Got it apart today. No needles were left in the lifter. Roller is worn down and it took the nose off the cam. Still have not found the lash cap. All other 15 lifters , pushrods ,etc. are fine. Pushrod was not bent as bad as I first expected but maybe .030. Could the lash cap have broken first and beat the lifter out? Taking pictures and will post when my kids come over to help. Am going to go with the mantons and a new cam/lifters. Galen
Re: Why did I bend a pushrod? [Re: galen] #849290
11/09/10 05:57 PM
11/09/10 05:57 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
No, lifter failed first, then out went the lash cap and subsequent issues. Not sure though if it simply was a catastrophic lifter failure, or something else that cause a lobe failure, but I'd put my money on bad lifter.
RIP Monte Smith
Re: Why did I bend a pushrod? [Re: CompWedgeEngines] #849291
11/09/10 11:36 PM
11/09/10 11:36 PM
Re: Why did I bend a pushrod? [Re: Cab_Burge] #849292
11/09/10 11:41 PM
11/09/10 11:41 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I just hope that's all it is and you can get it back together with out much pain
Re: Why did I bend a pushrod? [Re: WILD BILL] #849293
11/09/10 11:50 PM
11/09/10 11:50 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Also, Dont dismiss a tight valve guide. I have seen them be a hair to tight and something's gotta give.
Re: Why did I bend a pushrod? [Re: WILD BILL] #849294
11/09/10 11:59 PM
11/09/10 11:59 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Lash cap was in the pan. After checking everything you guys are right. Lifter failed. Pushrods,sockets and adjusters dont even have wear marks.My valve lash never moved and I change my oil every 500 miles. This engine does see a lot of 1500 to 2500 rpm street time. Lifters I had were supposed to oil the rollers. 2500 miles on them. What do you guys think of the isky lifters with no needles. The price is a little high for my taste. But now I have to buy a new cam, lifters, probably an oil pump and maybe bearings. This car is still my stress relief, gotta fix it.
Re: Why did I bend a pushrod? [Re: Bob_Coomer] #849295
11/10/10 12:02 AM
11/10/10 12:02 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks Bob, I will check that also. I am going to pull it out at this point and tear it down.
Re: Why did I bend a pushrod? [Re: galen] #849296
11/10/10 03:03 AM
11/10/10 03:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sorry to hear about that. That is one reason I decided to go flat tappet cam in my new eng as I drive it alot on the street. Ron
Re: Why did I bend a pushrod? [Re: 383man] #849297
11/10/10 09:53 AM
11/10/10 09:53 AM
Hard to beat Crower lifters marsh performance aka Moparts Connection-- board sponsor has them in stock--The Comps are JUNK
Re: Why did I bend a pushrod? [Re: Old School] #849298
11/10/10 11:24 AM
11/10/10 11:24 AM
New York
polyspheric Offline
polyspheric  Offline
New York
If there's any question about "is it enough?":
1. biggest possible improvement is to go larger diameter until it won't fit - there is no 10mm or 13/32" OD commercially available, but it would help if 7/16" won't fit.
With same .120" wall, and rating 3/8" as 100 units for a base:
10mm = +21%
13/32" = +36%
7/16" = +80%
1/2" = +198%
2. increased wall thickness is far less effective, only do this when #1 is not possible.
Boffin Emeritus
Re: Why did I bend a pushrod? [Re: polyspheric] #849299
11/10/10 01:37 PM
11/10/10 01:37 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
10mm = +21%
13/32" = +36%
7/16" = +80%
1/2" = +198%
Easy comparo for pushrod wall thickness: it's pretty close (never exactly) to new ÷ old.
.120" ÷ .083" = 45% stiffer
45% stiffer,if only I duplicate that.Bigger is always better,so I'am told
Re: Why did I bend a pushrod? [Re: ] #849300
11/10/10 02:34 PM
11/10/10 02:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Bull
I have been running them for years, best lifter in there price range.
Re: Why did I bend a pushrod? [Re: polyspheric] #849301
11/10/10 02:55 PM
11/10/10 02:55 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
That estimation isn't even close. I'm calculate that with a .375 OD pushrod going from a wall thickness of .083 to .120 (or an ID of .209 to .135) the increase stiffness is just 9%. And considering the additional mass one would be adding to the valve train I would say it isn't worth it!
moment of inertia = pi(OD^4-ID^4)/64. ID^4 is the killer.
This post is available in double vision where drunk.
Re: Why did I bend a pushrod? [Re: bwdst6] #849302
11/10/10 03:21 PM
11/10/10 03:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You're right - I typo'd it!
What do we learn from this: don't rely on memory, if you actually data.
Thanks.
Boffin Emeritus
