Why did I bend a pushrod?
#849283
11/08/10 11:22 PM
11/08/10 11:22 PM
Posts: 834 Missouri
galen
Missouri
Today I really needed a stress break so I took the car for a short drive. Drove around a little while and warmed everything up good. Ran it up to about 7200 through 1st and 2nd. Felt something. Backed out heard the miss and clatter. So far I have pulled the rockers. One lash cap is MIA. Pushrod is bent but still in place. Running offset lifters on the intakes and the correct amount of threads on adjusting screws. No galling, adjuster is ok. Good wear pattern on other lash caps. Going to pull the valley cover in the morning to check the lifter. Failure was #1 intake, 440-1s, Harland Sharps, Cam is not real radical. 263/270at.050. .690-lift. #1 cylinder leakdown ok. Springs 230#seat. I am running a smith brothers .083 wall 3/8 pushrod. What should I look for? Is it a pushrod strength issue. I had 2500 miles on it before but always shifted at 6800, this is the first at 7200.
Re: Why did I bend a pushrod?
[Re: galen]
#849284
11/08/10 11:28 PM
11/08/10 11:28 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Could the lash cap have come dislodged and cuased a piston to valve issue? Sorry to hear about the damage! Kind of makes a stress reliever go the wrong way.
68 Barracuda Formula S 340
[Re: Bad340fish]
#849285
11/08/10 11:40 PM
11/08/10 11:40 PM
Posts: 1,200 UK
602heavy
UK
Not saying it's you're problem but never had much luck using .083" pushrods in an RB when exceeding 600lb spring pressures , those .145" walls are belt & braces. Maybe go find another stress reliever. , just kidding.
[Re: galen]
#849287
11/09/10 01:49 PM
11/09/10 01:49 PM
Posts: 43,202 Bend,OR USA
Cab_Burge
I had a Smith Bros 3/8 .083 wall heat treated pushrod break in two pieces during a dyno test at 5600 RPM, it knock the top of the roller lifter off, bent the pushrod beside it and ended up dropping into the lifter bore gauging it and the cam lobe I had Smith Bros custom make them, told them all about the motor specs, spring pressures, intended RPM and so on I help some other local racers that own a dyno, they had one of there Smith Bros pushrod break the top off of one during a dyno test also I replace my Smith Bros with a set of seies 3 Manton .120 wall that Terry Manton recommended and that motor made 8 more HP at 300 RPM higher during the next dyno test, A,B,A after fixing the motor Smith Bros did replace the two bad ones free but didn't offer any other help on replacing or fixing the bushing, lifters and camshaft ( I didn't ask them to either )
[Re: galen]
#849288
11/09/10 03:58 PM
11/09/10 03:58 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Yea I have bent a couple and am going to a .120 wall next year for my roller cam. My last one went sitting idling in tech line last TT (for me) day and what a racket!! Made enough noise to be a kicked rod! In with a spare and off for some TT fun. Usually intakes too with that big offset!
[Re: galen]
#849290
11/09/10 05:57 PM
11/09/10 05:57 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
No, lifter failed first, then out went the lash cap and subsequent issues. Not sure though if it simply was a catastrophic lifter failure, or something else that cause a lobe failure, but I'd put my money on bad lifter.
RIP Monte Smith
[Re: Cab_Burge]
#849292
11/09/10 11:41 PM
11/09/10 11:41 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I just hope that's all it is and you can get it back together with out much pain
[Re: Bob_Coomer]
#849295
11/10/10 12:02 AM
11/10/10 12:02 AM
Posts: 834 Missouri
galen
Missouri
Also, Dont dismiss a tight valve guide. I have seen them be a hair to tight and something's gotta give.
Thanks Bob, I will check that also. I am going to pull it out at this point and tear it down.
[Re: 383man]
#849297
11/10/10 09:53 AM
11/10/10 09:53 AM
Hard to beat Crower lifters marsh performance aka Moparts Connection-- board sponsor has them in stock--The Comps are JUNK
[Re: Old School]
#849298
11/10/10 11:24 AM
11/10/10 11:24 AM
Posts: 4,206 New York
polyspheric
New York
If there's any question about "is it enough?": 1. biggest possible improvement is to go larger diameter until it won't fit - there is no 10mm or 13/32" OD commercially available, but it would help if 7/16" won't fit. With same .120" wall, and rating 3/8" as 100 units for a base: 10mm = +21% 13/32" = +36% 7/16" = +80% 1/2" = +198% 2. increased wall thickness is far less effective, only do this when #1 is not possible.
Boffin Emeritus
[Re: polyspheric]
#849299
11/10/10 01:37 PM
11/10/10 01:37 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
If there's any question about "is it enough?": 1. biggest possible improvement is to go larger diameter until it won't fit - there is no 10mm or 13/32" OD commercially available, but it would help if 7/16" won't fit. With same .120" wall, and rating 3/8" as 100 units for a base: 10mm = +21% 13/32" = +36% 7/16" = +80% 1/2" = +198% 2. increased wall thickness is far less effective, only do this when #1 is not possible. Easy comparo for pushrod wall thickness: it's pretty close (never exactly) to new ÷ old. .120" ÷ .083" = 45% stiffer
45% stiffer,if only I duplicate that.Bigger is always better,so I'am told
[Re: polyspheric]
#849301
11/10/10 02:55 PM
11/10/10 02:55 PM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
That estimation isn't even close. I'm calculate that with a .375 OD pushrod going from a wall thickness of .083 to .120 (or an ID of .209 to .135) the increase stiffness is just 9%. And considering the additional mass one would be adding to the valve train I would say it isn't worth it!
moment of inertia = pi(OD^4-ID^4)/64. ID^4 is the killer.
This post is available in double vision where drunk.
[Re: bwdst6]
#849302
11/10/10 03:21 PM
11/10/10 03:21 PM
polyspheric
New York
You're right - I typo'd it!
What do we learn from this: don't rely on memory, if you actually data. Thanks.
Boffin Emeritus
