Walker muffler VS Accurate Exhaust #849240
11/08/10 10:32 PM
11/08/10 10:32 PM
Michgian
moparfun340 Offline OP
Michgian
I have a 1973 challenger and I am looking for a stock sounding exhaust in duals. Do you think Walker mufflers will sound as good a Accurate Exhaust because Walker is a lot less money. Walker has a muffler that will fit beside the gas tank but it says it is very a 318 single exhaust. Do you think it would sound good with duals. Thanks for your help.
Re: Walker muffler VS Accurate Exhaust [Re: moparfun340] #849241
11/09/10 11:14 AM
11/09/10 11:14 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Walker makes a nice muffler. When I worked at an Exhaust Pros shop, we used Walker mufflers. The round muffler walker makes look very close to the origonal style. It will sould just fine. If you end up going that route, let me know what part #'s you used for the muffler and resonator. The shop where I worked doesn't exist any more. It's too bad because my boss was great at dual exhaust jobs and he was cheap.
The only problem I can see is that the mufflers from Accurate come with a bracket welded onto the back so you can use the factory style hanger. You'd have to find an origonal bracket to weld to your replacement in order to use the factory setup.
If you want a slightly more agressive sound, walker also makes an all welded(not crimped) turbo muffler that is close to the size of the factory muffler and resonator.
Re: Walker muffler VS Accurate Exhaust [Re: burdar] #849242
11/09/10 02:00 PM
11/09/10 02:00 PM
Michgian
Michgian
Do you think it will sound good without resonators and just the walker muffler because on a 318 it does not call for a resonator with these mufflers.
Re: Walker muffler VS Accurate Exhaust [Re: moparfun340] #849243
11/09/10 02:17 PM
11/09/10 02:17 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Walker mufflers are just a generic stock replacement muffler designed to fit many applications. If you brought a 340 car into a shop, they would put those same mufflers on. It doesn't matter what engine the car has as long as the muffler fits where the factory one was.
On my 318 Challenger, I'm adding dual exhaust. I'm going to have it look like the factory 340 system so I'm going with resonators too. I think the 318 dual exhaust systems from Accurate are just the 340 system with different head pipes to connect to the 318 manifolds.
The Walker mufflers will sound fine. If you don't want to run resonators, you may get some droning under part throttle cruise. That's all the resonators are designed to eliminate.
If a 318 would have been offered with dual exhaust, the factory would have used resonators. The only reason they didn't is because the single exhaust muffled the sound enough already.
Re: Walker muffler VS Accurate Exhaust [Re: burdar] #849244
11/09/10 02:52 PM
11/09/10 02:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Walker was an OEM supplier to Chrysler; years ago I replaced my '69 Roadrunner's original system with Walker pipes (exhaust & tail), and they were identical. I used some NOS mufflers. It's likely that the Walker aftermarket mufflers aren't identical to the factory ones for cost reasons or multiple applications so muffler shops don't have to stock as many variations.
I would expect the OP's car to sound barely louder with OEM-style duals & mufflers than it does now with the single, no drone. You'll be able to hear the motor, but even low radio volumes will be louder than the exhaust.
Re: Walker muffler VS Accurate Exhaust [Re: topside] #849245
11/09/10 03:37 PM
11/09/10 03:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
When I did my former challenger 340 I wanted a bit more 'sound' to it.
So I left off the resonators, it barely made a difference driving down the road and I don't think it made any difference while idling at stops.
