Dependable 500 stroker out of a 400 block? #84905
07/06/08 06:15 PM
07/06/08 06:15 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I have looked at a few Mopar sites that have stroker kits to make a 500 cu. inch using a 400 block. It is my understanding that this combination using a 4.15 stroke crank the engine life is shortened because the piston is short.
Can anyone give me more information on this or tell me who makes a very dependable 500 cu. inch stroker? The engine will be used a little on the street mut will be used at the track also.
Thank you!
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84906
07/06/08 07:48 PM
07/06/08 07:48 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i built a 500"-400 for some friends to bracket race. it has an eagle crank, bill miller alum rods, and je pistons. the rods required some healthy notches at the bottom of the cylinders. the short pistons hang out the bottom of the bores some. short pistons should run tighter clearances to keep them stable. i don't think that "short piston" should necessaryily equate to "shorter life". a lot of high rpm endurance engines use very short pistons. i was concerned about a short piston hanging to far out the bottom of the bore and becoming unstable. so far the engine has held together and been pretty reliable.
Re: Dependable 500 stroker out of a 400 block? [Re: lewtot184] #84907
07/06/08 08:17 PM
07/06/08 08:17 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks for your reply!
So the engine you built is only used at the drag strip? or on the street also?
I was also wondering if someone made a taller piston maybe with a shorter rod??? for a better durabilty /longlife of the engine? Or is that a bad idea?
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84908
07/06/08 08:38 PM
07/06/08 08:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you can get anything you want made . a taller piston is a piece of cake , talk to someone that builds engines like you are interested in and have a piston and rod combo speced.
another thing to consider is compression ratio , you need to decide what fuel you want to use and what cylinder head so the piston can be speced accordingly , i'll assume you want a pump gas friendly combo , expect a piston with a D shaped dish , Diamond has shelf stock pistons that may fit the bill and is you want a taller piston for a samll upcharge they can chamnge the compression height to work with a specific rod , which will probably something based off a big block chevy derivative so you'll need a crank with a 2.2 rod journal .
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84909
07/06/08 08:43 PM
07/06/08 08:43 PM
AndyF Online content
AndyF  Online Content
A 470 motor with a 3.90 or 3.915 stroke crank works really well in a low deck. That size of stroke gives you enough height to use a taller piston and a decent length connecting rod.
Re: Dependable 500 stroker out of a 400 block? [Re: JohnRR] #84910
07/06/08 08:53 PM
07/06/08 08:53 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks John for the information. The problem is the closest engine builder mainly builds Chevy for roundy-round cars. I would like to use the 400 (230-block) that I have for a Drag racing fun as well as a little local street use. I also think I would like to use the new Edelbrock Victor aluminum heads or maybe the Indy heads?
Re: Dependable 500 stroker out of a 400 block? [Re: AndyF] #84911
07/06/08 09:00 PM
07/06/08 09:00 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Andy...Thanks for your input!
I have thought about a 470 but naturally there is no substatution for cubic inches.
Do you know the horse power and torq of the engine you built?
Do you know what the gram weight of the rods and pistons? Did it rv up quick?
One of the things I want the engine to do is rev up very quick and I will be using a 4-speed Hemi transmission so if I can get the engine to pull at 7000 RPM that would be great!
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84912
07/06/08 09:27 PM
07/06/08 09:27 PM
what input? all he said was to build a 470 . that said,
and to answer your original question, yes you can build a dependable
500cid from a 400 and have many years of street duty. or at the least,
440source seems to think so.
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84913
07/06/08 09:54 PM
07/06/08 09:54 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If you want it to pull to reliably to 7,000rpm for several years,go for the 470 that Andy suggested.
Sheldon
Re: Dependable 500 stroker out of a 400 block? [Re: AndyF] #84914
07/06/08 09:54 PM
07/06/08 09:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've done both the 470 and 500. my personal preference is the 470 whether street or strip.
Re: Dependable 500 stroker out of a 400 block? [Re: lewtot184] #84915
07/06/08 10:00 PM
07/06/08 10:00 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
O.K. Guys...The 470 does look good. If you have built one of these and run it...Do you know what HP and Torq the motor had/has? What RPM did you take the motor to ?
Thank you very much !
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84916
07/06/08 10:18 PM
07/06/08 10:18 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
if your building all out race a-body go with 400=500 deal.but remember it will cost more external oiling pan and kit, cant use stock pickup.cant use stock motor mounts wont fit. now you will have to go motor plate.id say go with 440 block, 500 inch kit is drop in deal with ceby or mopar crank pins.stock pan,pickup, mounts fit fine
MOPAR OR NO CAR
Re: Dependable 500 stroker out of a 400 block? [Re: hemigod426] #84917
07/06/08 10:25 PM
07/06/08 10:25 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I never thought about the stock style pick up not working. The reason I was going to use the 400 block was;
1. I have a 1971 400 "230 block"
2. The "B" engine is a little smaller than a 440 and is lighter.
3. Exhaust I thought would be easier in an "A" body.
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84918
07/06/08 10:29 PM
07/06/08 10:29 PM
hemigod426 Offline
hemigod426  Offline
go with 451 cube 400, all stock parts fit and it will be plenty for street/strip a-body
MOPAR OR NO CAR
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84919
07/06/08 10:35 PM
07/06/08 10:35 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
The 470 or the 512 job gives you more of a compression distance than the 500 inch job. To me, either one would need a head that flows in the 350cfm range with a intake manifold that is equal to the cfm range of the heads.
Engine by DeTar http://www.kansasbadman.com
Re: Dependable 500 stroker out of a 400 block? [Re: hemigod426] #84920
07/06/08 10:40 PM
07/06/08 10:40 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well I had a 451 built about 15 years ago and it worked o.k. but I wasn't overly impressed.
2-years ago I had a 496 cubed 440 built for my 1 ton and I really like it as far as a torq monster. It not set up like one for a high performance car but I can see it's potential.
If I can fit a 440 size block easily into my 67 Barracuda and have room for large tube under chassy headers I would go that route but I also want to consider the weight of the 440 block vs. the 400 block.
Re: Dependable 500 stroker out of a 400 block? [Re: GLR] #84921
07/06/08 11:37 PM
07/06/08 11:37 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
My 500" lowdeck uses stock motor mounts, did not require an external oiling kit, and uses a stock 1/2" pick up. Just needed careful attention to the clearancing for the block and rods.
Re: Dependable 500 stroker out of a 400 block? [Re: Jeff_383] #84922
07/06/08 11:42 PM
07/06/08 11:42 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
How do you like your 500 cu. inch stroker?
Did you build it? Was it a kit or?
What body car do you have it in?
Do you know it's HP and torq?
Re: Dependable 500 stroker out of a 400 block? [Re: Jeff_383] #84923
07/06/08 11:42 PM
07/06/08 11:42 PM
there are no stock 1/2" lowdeck oil pickups.
Re: Dependable 500 stroker out of a 400 block? #84924
07/07/08 12:05 AM
07/07/08 12:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1/2 pickup is PAN dependent and you can get around that if you use your brain ,it's has nothing to do with the blocks deck height .
if you want to get TECHNICAL there were no WEDGE MOTORS with a 1/2 pickup .
