Hi=po 340 manifolds #848614
11/08/10 02:35 AM
11/08/10 02:35 AM
Missouri
Confusedcuda Offline OP
Missouri
How much better if any, do Headers flow better than 340 hi-po manifolds?
Re: Hi=po 340 manifolds [Re: Confusedcuda] #848615
11/08/10 02:43 AM
11/08/10 02:43 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
They flow way way better than manifolds.
Re: Hi=po 340 manifolds [Re: Confusedcuda] #848616
11/08/10 08:51 AM
11/08/10 08:51 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The following is a chart that was in one of the magazines. It shows dyno results on different sb's with different exhaust bolted on.
6291118-340hpTTi.pdf (208 downloads)
Re: Hi=po 340 manifolds [Re: YO7_A66] #848617
11/08/10 11:25 AM
11/08/10 11:25 AM
Missouri
Missouri
Cool! Thanks! So it looks like you loose around 5 hp or so with the manifolds.
Re: Hi=po 340 manifolds [Re: Confusedcuda] #848618
11/08/10 11:34 AM
11/08/10 11:34 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I think it's a good deal more than 5 hp. On my old Duster I went from early style 340 manifolds to a set of TTI's and cut the ET in the 1/4 by .5 sec and picked up 5 mph trap speed. In my mind that comes out to at least 30 hp., probably a bit more.
Re: Hi=po 340 manifolds [Re: Confusedcuda] #848619
11/08/10 12:08 PM
11/08/10 12:08 PM
NE
moparpoolman Offline
NE
It would depend on the specs the motor is built to as to how much gain there would be with headers. With more compression and a larger cam the gain would be much greater with headers. If the motor is stock then the differences would be less.
Re: Hi=po 340 manifolds [Re: moparpoolman] #848620
11/08/10 07:40 PM
11/08/10 07:40 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I don't have a link, but look at what the F.A.S.T. guys are running through HP manifolds.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Hi=po 340 manifolds [Re: GO_Fish] #848621
11/08/10 08:48 PM
11/08/10 08:48 PM
I remem that article claiming a 5 horse diff & I dont buy it unless the ex from the header pipe/or the collector was the same restricted size as I believe no matter what the backpressure you can only force so much total flow thru a particular dia orifice (in the rest of the ex sytem rearward) as power production, it's (mainly) about overall flow (in/out) but if an engineer (& there are several on here) enlightens me (that flow will always increase no matter what the dia in question if the psi is higher) then I stand corrected. Does a given dia reach a point where it will not flow any more (rate) no matter what??? & if so at what psi in oiling passages is enough & over that is wasted power & stress on the inter shaft/gear & pump as the bypass stabilizes it at that point.
Re: Hi=po 340 manifolds [Re: RapidRobert] #848622
11/08/10 10:04 PM
11/08/10 10:04 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
FAST racing Lots of 340 cars in the 12's AND 11's using HP 340 manifolds and stock tire sizes.
Are headers an easier way to go fast? Yes, but they have drawbacks also. You can go fast without headers.
Re: Hi=po 340 manifolds [Re: GO_Fish] #848623
11/08/10 10:08 PM
11/08/10 10:08 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I sure do agree with that last post
