where is the obdI plug? 90 ram van. #848542
11/07/10 11:45 PM
11/07/10 11:45 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
I can't seem to locate it.
1969 Dart
Re: where is the obdI plug? 90 ram van. [Re: Shaggy] #848543
11/08/10 01:20 AM
11/08/10 01:20 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
probably under teh dash, pointing down at the carpet somewhere around the steering column...that's where it is on my 98, although it's OBDII, I don't see why they plug locations would change...
**Photobucket sucks**
Re: where is the obdI plug? 90 ram van. [Re: Shaggy] #848544
11/08/10 01:22 AM
11/08/10 01:22 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think it's under the hood, near the center of the firewall about where the PCM is located.
Should be a black L shaped connector
Re: where is the obdI plug? 90 ram van. [Re: gtx6970] #848545
11/08/10 10:21 AM
11/08/10 10:21 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree its under the hood.You will need the chrysler adapter also to hook into it.Rocky
Chrysler Firepower
Re: where is the obdI plug? 90 ram van. [Re: therocks] #848546
11/09/10 02:39 AM
11/09/10 02:39 AM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
Was under the hood. But....I can't reset the maintenance light with the scanner I have.
Re: where is the obdI plug? 90 ram van. [Re: Shaggy] #848547
11/09/10 09:34 AM
11/09/10 09:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
There were a bunch of different procedures for resetting the maint light.Some had a switch some a battery had to be replaced.You need to find out thru All Data or Mitchells etc how to reset it.Rocky
Chrysler Firepower
Re: where is the obdI plug? 90 ram van. [Re: therocks] #848548
11/09/10 11:56 AM
11/09/10 11:56 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Did my 89 with an old snap-on scanner. Took a while to find the darn set-up, and had to do it twice for it to take.
Good Luck!
Re: where is the obdI plug? 90 ram van. [Re: RodStRace] #848549
11/09/10 06:21 PM
11/09/10 06:21 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
I have an actron scanner. What needed to be done with the snap on scanner to reset it? I can reset/clear the codes but not the maintanence light....
Re: where is the obdI plug? 90 ram van. [Re: Shaggy] #848550
11/09/10 07:33 PM
11/09/10 07:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
which light is on?
the ck engine/service engine soon light or the maint required light?
Re: where is the obdI plug? 90 ram van. [Re: gtx6970] #848551
11/09/10 08:21 PM
11/09/10 08:21 PM
Minnesota
Shaggy Offline OP
Shaggy  Offline OP
Minnesota
which light is on?
I could just pull the bulb, but would rather not.
Noticed it has a reman computer today.
Re: where is the obdI plug? 90 ram van. [Re: Shaggy] #848552
11/09/10 08:32 PM
11/09/10 08:32 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I had to do a friend's Ram truck too, and can't remember the exact process.
It was not in the data and codes menu, it was in a separate area.
Re: where is the obdI plug? 90 ram van. [Re: RodStRace] #848553
11/10/10 12:37 AM
11/10/10 12:37 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
The snap on scanners can reset those,I think it was under the special functions section.That is a seperate unit from main computer,Turns one by pre determined time/miliege.Supposed to have emission system checked for proper working.(eg)egr valve, cat conv,vacuum hoses,etc.I can look on mitchell wednesday for procedure.Some needed the module replaced,some had a 9v battery to replace,some even had a button you just push.unit is behind the instrument cluster/dash.Light has NO indication of an actuall problem.
Re: where is the obdI plug? 90 ram van. [Re: moretoys] #848554
11/10/10 10:38 AM
11/10/10 10:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
90 I believe was a battery replace.They used probally 4 or 5 different setups in those years.I do remember some had a switch ubder the dash that needed flipped and some had a button that needed pushed in.Its in All Data how to reset.Id do a Google search and see what it says.Rocky
Chrysler Firepower
