67 a body instrument cluster voltage regulators? #84849
07/06/08 03:22 PM
07/06/08 03:22 PM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
Does anyone know where to buy these, my temp gauge started acting goofy and my fuel gauge doesnt work. Could this be the problem? It's on a 67 dart if it matters..
Re: 67 a body instrument cluster voltage regulators? [Re: Chally426] #84850
07/06/08 03:27 PM
07/06/08 03:27 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
It is part of the gas gauge, the gas gauge has three terminals on it, one for 12V in one for 5V out to the other gauges and one from the sending unit.
I do not remember which is which, but...
So you need a new gas gauge or do some "creative" wiring to use a 7805 (solid state V reg replacement) - as I have done...
RAR
Re: 67 a body instrument cluster voltage regulators? [Re: 6T6Cuda] #84851
07/06/08 03:32 PM
07/06/08 03:32 PM
Columbus, Ohio
Columbus, Ohio
So, your saying that it does controll the fuel gauge.
They are not avalible anywhere?
Re: 67 a body instrument cluster voltage regulators? [Re: Chally426] #84852
07/06/08 04:09 PM
07/06/08 04:09 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
It is integral to the fuel gauge, it is not replaceable separate; you need to get a new fuel gauge or "hack" it to use an external regulator (which is what I have done)
Re: 67 a body instrument cluster voltage regulators? [Re: 6T6Cuda] #84853
07/06/08 04:14 PM
07/06/08 04:14 PM
Columbus, Ohio
Columbus, Ohio
We must be talking about two differant things, The part I'm talking about plugs into the back of the circut board on the left side of the cluster. It's about an 1 1/2" long and has three like prongs on it.
Re: 67 a body instrument cluster voltage regulators? [Re: Chally426] #84854
07/06/08 04:20 PM
07/06/08 04:20 PM
Columbus, Ohio
Columbus, Ohio
Here is a pic
Re: 67 a body instrument cluster voltage regulators? [Re: Chally426] #84855
07/06/08 04:42 PM
07/06/08 04:42 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
here ya go
https://www.rockauto.com/dbphp/mak,PLYMOUTH,1967
look under electrical, then; Instrument Cluster Voltage Regulator
and below is the discription
1967 PLYMOUTH SATELLITE 5.2L 318cid V8 : Electrical : Instrument Cluster Voltage Regulator Related Parts
Item Price Core Total
STANDARD MOTOR PRODUCTS Part # VRC601 {INSTRU. CLUSTER VOLTAGE REGULATOR}
$37.79 $0.00 $37.79
Re: 67 a body instrument cluster voltage regulators? [Re: ngpSatellite] #84856
07/06/08 06:12 PM
07/06/08 06:12 PM
Columbus, Ohio
Columbus, Ohio
Thanks, thats it. Now, if this is bad, will it effect the fuel and temp gauge?
Re: 67 a body instrument cluster voltage regulators? [Re: Chally426] #84857
07/06/08 06:35 PM
07/06/08 06:35 PM
own private Idaho
N
N
own private Idaho
I had both my gas and temp indicator reading 1/2 of what they were suppose to read and changed the regulator and it fixed the problem the voltage reg brings 5v to the (two conections per instrument)temp and fuel guage..... both guages other terminal goes to ground. fuel indicator goes thru the fuel pickup and the temp thru the temp thermostat...both acting as variable resistors so if both are giving you bad reading that VR is a logical guess but until you change it and see ya don't really know HOPE THAT EXPLAINATION MAKES SENSE!!!
Re: 67 a body instrument cluster voltage regulators? [Re: ngpSatellite] #84858
07/06/08 08:39 PM
07/06/08 08:39 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
You are right - that is different... the 67 barracuda is different.... I thought all a-bodies did it through the fuel gauge.
The voltage reg is used by the fuel gauge, temp gauge and the oil pressure (not the amp gauge though)
Re: 67 a body instrument cluster voltage regulators? [Re: 6T6Cuda] #84859
07/07/08 12:04 AM
07/07/08 12:04 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
No oil pressure guage in a 67-69 Dart. But, yes the IVR controls voltage to the fuel guage and the temp guage.
Re: 67 a body instrument cluster voltage regulators? [Re: Jim_Lusk] #84860
07/07/08 12:14 AM
07/07/08 12:14 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Only the rallye type dash(round speedo and round gauge cluster) has the volt limiter built in. 67 dart should use the plug in limiter like many B bodies.
Re: 67 a body instrument cluster voltage regulators? [Re: buildanother] #84861
07/07/08 10:38 AM
07/07/08 10:38 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
And the "rallye" dash wasn't available in a 67 Dart....
Re: 67 a body instrument cluster voltage regulators? [Re: Jim_Lusk] #84862
07/07/08 10:42 AM
07/07/08 10:42 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you take a test light and hook it between any of the sender wires and ground it should show a steady blinking. If it does then the limiter is working correctly.
