Re: 67 a body instrument cluster voltage regulators?
[Re: Chally426]
#84855
07/06/08 04:42 PM
07/06/08 04:42 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
here ya go https://www.rockauto.com/dbphp/mak,PLYMOUTH,1967 look under electrical, then; Instrument Cluster Voltage Regulator and below is the discription 1967 PLYMOUTH SATELLITE 5.2L 318cid V8 : Electrical : Instrument Cluster Voltage Regulator Related Parts Item Price Core Total STANDARD MOTOR PRODUCTS Part # VRC601 {INSTRU. CLUSTER VOLTAGE REGULATOR} $37.79 $0.00 $37.79
[Re: 6T6Cuda]
#84859
07/07/08 12:04 AM
07/07/08 12:04 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
You are right - that is different... the 67 barracuda is different.... I thought all a-bodies did it through the fuel gauge.
The voltage reg is used by the fuel gauge, temp gauge and the oil pressure (not the amp gauge though)
No oil pressure guage in a 67-69 Dart. But, yes the IVR controls voltage to the fuel guage and the temp guage.
[Re: buildanother]
#84861
07/07/08 10:38 AM
07/07/08 10:38 AM
Jim_Lusk
Fresno, CA
Only the rallye type dash(round speedo and round gauge cluster) has the volt limiter built in. 67 dart should use the plug in limiter like many B bodies.
And the "rallye" dash wasn't available in a 67 Dart....
