Engine build advice #848319
11/07/10 09:00 PM
11/07/10 09:00 PM
Out in Left Field, NY
bobs66440 Offline OP
Looks like I'm going to have to replace/rebuild my tired, oil-thirsty 440.
Option A: Have the bottom end redone locally (and have them put in a hotter-than-stock cam) and put on a set of those near-stock cast iron Aero heads. I want to re-use the dual-quad setup I have and put on a pair of HP exhaust manifolds I have. This would run me probably about $2500-$3000. or so.
Option B: Get a remanufactured long block from this place...
http://www.rebuilt-engine-blocks.com/engines/Automobile_Engine_MOP_440LB_CHRYSLER.html
...ask for a mild performance upgrade, throw my stuff on it and call it a day for about a grand less.
I would love to have a 600hp beast, but the car and my wallet aren't up to it. At this point, I am just looking for a reliable driver...
Any opinions on which might be the best option?
Thanks.
Also, what would be a good cam grind to get a nice, lopey-ish idle but good drivability.
Re: Engine build advice [Re: bobs66440] #848320
11/07/10 09:12 PM
11/07/10 09:12 PM
forget the Aero (or any other) iron heads & get some alum 440sources' stealth heads possibly from someone here on the board to check them out. KB pistons
Re: Engine build advice [Re: bobs66440] #848321
11/07/10 09:23 PM
11/07/10 09:23 PM
Under My Car
Mopar_Country Offline
Under My Car
Winter is coming, plenty of time for a rebuild. You are going to spend 2000.00 and still won't know for sure what you got. Pull the engine and rebuild, do a little research for machining, parts etc and have at it.
Re: Engine build advice [Re: Mopar_Country] #848322
11/07/10 10:44 PM
11/07/10 10:44 PM
I tend to agree. If there are any issues, I can just drive the car there. I suppose the problem would be to find a shop that's competent at Mopars...Chevy savvy shops are plentiful around here. Anyone have a suggestion in the NY Tri-State area??
Re: Engine build advice [Re: bobs66440] #848323
11/07/10 11:59 PM
11/07/10 11:59 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
as it seems with your post,with you (and most everybody else) pricey,and consequently un-needed aluminum heads are not in the budget. the aero heads will work great with the combo you are looking to assemble,comp XE268 is a great cam,and any number of manufactures can supply a set of cast pistons to more than suffice. it's amazing the "advice" you can get on here when others are spending your money.......
Re: Engine build advice [Re: superbyrd] #848324
11/08/10 12:22 AM
11/08/10 12:22 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Will you pull the engine out,or just drop the car off and open your wallet? Where are you in the tri area.?Any decent shop will have a waiting list to "get er done"What are your peformance goals?Do NOT short change the build,if what you want is not in the budget,concider saving up and do it right the FIRST TIME
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Engine build advice [Re: superbyrd] #848325
11/08/10 12:29 AM
11/08/10 12:29 AM
Byrd I think he's capable of sorting thru the "advice" he will recieve here & make an informed decision which would include checking how close the Aero and stealth heads are to each other, plus the closed chambers plus better flow plus losing weight plus Aero has quality control issues (on occaision). We are not on here to critisize other peoples' "advise" but to offer "advise" and then let the OP sort thru it & make the best possible plan.
Re: Engine build advice [Re: RapidRobert] #848326
11/08/10 12:40 AM
11/08/10 12:40 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Don't waste your money on the areo heads, you can get a $250 valve job on the heads you have and get the same results as the aeroheads. Pay attention to the shortblock rebuild, don't let them put low compression pistons in it which is what you would end up with that online link or if you went to a so called chevy savy shop.
Re: Engine build advice [Re: JohnRR] #848327
11/08/10 12:57 AM
11/08/10 12:57 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
i appoligize rapidrobert. my mistake. i goofed up,i thought i read the OP,the words "just a reliable driver", "budjet" "not in the wallet",etc. i'm sorry,by all means,to the original poster, since the 440source aluminum heads are so close to the aeros ($499 pair compared to $1000 pair,but hey,what do i know about "so close"lol) for just a "basic,reliable rebuild" yes,you really need those aluminum heads,etc.
seriously though, i agree with johnrr,if you can re-use your heads,and get by with just a valve job,then that would be the cheapest route. but if they need alot more work,the aeros would come in under the price of re-doing the originals.
Re: Engine build advice [Re: superbyrd] #848328
11/08/10 01:02 AM
11/08/10 01:02 AM
U.S.S.A.
U.S.S.A.
Till you add in shipping , possible core charge and having the less than stellar valve job corrected ...
Re: Engine build advice [Re: bobs66440] #848329
11/08/10 01:36 AM
11/08/10 01:36 AM
Norwood NC
HP Engines Offline
HP Engines  Offline
Norwood NC
I would be careful with one of those online deals
unless its a known and reputable shop.
Comp Cams extreme energy hyd. platform would be
ideal for your applic.
BTW if your close to N.C. I run a Mopar savvy
engine shop. www.HPENGINES.NET
GOOD LUCK with yur build
Re: Engine build advice [Re: HP Engines] #848330
11/08/10 02:24 AM
11/08/10 02:24 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
If he is in the NE, Dwayne Porter can't be all that far away...
Re: Engine build advice [Re: SomeCarGuy] #848331
11/08/10 02:28 AM
11/08/10 02:28 AM
U.S.S.A.
U.S.S.A.
Not that close ,OP is in the NY , NJ, PENN area , that's tri state , Dwayne is at least 300 miles away .
Re: Engine build advice [Re: JohnRR] #848332
11/08/10 07:29 AM
11/08/10 07:29 AM
Wow! Thanks for all the replies! A lot of good info. I never thought of just re-doing the existing heads...don't know why but that sounds like the best option. There's a shop not too far from me I heard of that builds Hemis among others, maybe I'll drive it over to him and see what he says.
Thanks guys
Re: Engine build advice [Re: bobs66440] #848333
11/08/10 08:07 AM
11/08/10 08:07 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't know your mechanical abilities, but pulling an engine is pretty simple to do yourself, if you're talking about driving the car over, dropping it off, and having them call you when it's done...that's contradicting your budget requirements.
not to mention, you don't really know what you're getting.
If you're on a true budget, I would go for a stock-ish rebuild with good pistons that get you zero deck for some decent compression. keep everything else "stock" except for the bump stick.
put it all together yourself, and save some money.
if i wanted a stock-ish build, this is what I would do:
polish/turn the crank
resize the rods
punch the block .030 over, if needed
have the decks squared/trued up
have hte mains align checked and honed if need correction
valve job on YOUR heads (not someone elses "stock heads" by mail-order)
new cam/lifters (you wanted to bump up over stock a bit)
new timing chain
new harmonic dampner
have the assembly balanced
take your time, read up on some books, ask lots of questions here, and put it together yourself.
I'm thinking you could get a solid 400-425 hp from that 440 for around $3,000 if you do a lot of it yourself.
if you drive it to a shop and drop it off...double that, and still only have a "bone stock rebuild" with a much longer wait.
**Photobucket sucks**
Re: Engine build advice [Re: 70Cuda383] #848334
11/08/10 08:09 AM
11/08/10 08:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
By the way, the first engine I ever built is my 383 stroked to 438, aluminum headed, 535 lbs of torque, 505 hp beast thats in my dakota.
I got the confidence to do this by myself by reading a few Mopar rebuild books, and asking lots of questions on here...and dare I say...it was actually pretty easy to do, just ask lots of questions as you go!
Re: Engine build advice [Re: Mopar_Country] #848335
11/08/10 08:58 AM
11/08/10 08:58 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Re: Engine build advice [Re: 70Cuda383] #848336
11/08/10 09:14 AM
11/08/10 09:14 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
resize the rods
new timing chain
Man if he's looking for budget build, he doesn't need all that block work you mentioned.
Crank is OK also if the engine bearings look OK.
Re: Engine build advice [Re: 70Cuda383] #848337
11/08/10 09:51 AM
11/08/10 09:51 AM
I had planned on driving it over to chat with him about it...so he could get a visual. Then I would would pull the engine, run it over to him and let him do the work. I would have him put the cam in and install the heads and probably the oil pan, but I would put on the intake and all the accessories, etc. and re-install it.
As far as machine work goes, I will probably rely on him to tell me what it needs to make it a reliable engine.
Re: Engine build advice [Re: bobs66440] #848338
11/24/10 08:55 AM
11/24/10 08:55 AM
Well, it looks like it's going to be a rebuild. I plan on building it with as much power and reliability as I can afford. It's stock now but very tired and using a lot of oil. It's going to be a low budget build (hopefully under $3500.) I have stock heads and plan on going through them, but would like some port work (suggestions?) to help them breathe better due to the dual quad I am currently running. The cam a little lumpy but not crazy. The bottom end will remain stock with new rings/bearings etc...maybe some decent pistons (suggestions?). I am putting on factory HP exhaust manifolds. The r&p is 3.55. The tire size is 245/60x14. 4 speed. It's going to be primarily a street cruiser...but healthy sounding/running. I have this cam already. Opinions?
I would like to get 400+hp and 500+ tq. out of it. Is this realistic? Thanks!
