firewall grommet for dash reverse light wire #847635
11/06/10 10:23 PM
11/06/10 10:23 PM
Connecticut
biginchmotor Offline OP
Connecticut
I purchased a dash mounted reverse light for my 74 Barracuda. No rubber grommet came on the wire. have not drilled the hole in the firewall yet. Is this grommet available anywhere? Would someone have a original they could post a picture of? Thanks John.
Re: firewall grommet for dash reverse light wire [Re: biginchmotor] #847636
11/06/10 11:31 PM
11/06/10 11:31 PM
NJ
rth Offline
rth  Offline
NJ
i didn't think wire went through f/wall.did you check wiring diag?
Re: firewall grommet for dash reverse light wire [Re: rth] #847637
11/07/10 12:43 AM
11/07/10 12:43 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
The wire is supposed to have a grommet. And it goes on reverse of how you'd think it would (long end points into the engine bay).
Re: firewall grommet for dash reverse light wire [Re: PAINT IT BLACK] #847638
11/07/10 01:23 AM
11/07/10 01:23 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
i think it should be simply spliced inside the cab, maybe at bulkhead itself where the tranny harnees get into the cab. White or white traced wire, I can't recall wich one, but simply just the one what is energized when gearing R
Re: firewall grommet for dash reverse light wire [Re: NachoRT74] #847639
11/07/10 11:45 AM
11/07/10 11:45 AM
Connecticut
Connecticut
Hoping someone could post a picture of a 73-74 Barracuda / Challenger 4 speed car firewall picture in the area of the bulkhead connector...John.
Re: firewall grommet for dash reverse light wire [Re: biginchmotor] #847640
11/08/10 01:28 AM
11/08/10 01:28 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
70 only grommet is on the left.
71 and up used the larger grommet on the right.
Hole should be 1 inch for a snug fit
Re: firewall grommet for dash reverse light wire [Re: mccannix] #847641
11/08/10 07:33 PM
11/08/10 07:33 PM
Connecticut
Connecticut
Thanks so much for the picture...that is just what I needed. Now to find the grommet...John.
Re: firewall grommet for dash reverse light wire [Re: mccannix] #847642
11/08/10 10:15 PM
11/08/10 10:15 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Hi Terry,
Is the 70 only also 1" and is cuda and challenger the same size but different location?
do you have a picture of grommet looking from the other side
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: firewall grommet for dash reverse light wire [Re: VCODE] #847643
11/09/10 06:07 PM
11/09/10 06:07 PM
Ontario, Canada
Ontario, Canada
Bob
I shouldn't have been so quick to state 71 and up. I do know that my 71 340 Cuda June built has the large grommet and my 70 Cuda has the smaller one. Both have original grommet/wiring.
Earlier 71's may have used the smaller grommet as well until a certain cutoff date. The location where the wire and grommet are on the firewall are different locations since the 70 firewall has some differences from the 71 and later firewall.
I'll try and get a picture of the other side of the grommet
