Dads Magnum tach quit #847314
11/06/10 04:02 PM
11/06/10 04:02 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
2005, Hemi, loaded. 60,000 miles, and the tach stopped for no reason. Stealership said $900 to replace the cluster. Anything make sense here?
Re: Dads Magnum tach quit [Re: da50r] #847315
11/06/10 04:17 PM
11/06/10 04:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pull the cluster and reseat it.
Re: Dads Magnum tach quit [Re: stumpy] #847316
11/06/10 04:20 PM
11/06/10 04:20 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Reseat or reset? How big of a deal is this car to pull the cluster?
Re: Dads Magnum tach quit [Re: da50r] #847317
11/06/10 04:34 PM
11/06/10 04:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Reseat and I have no idea. I just have heard that a lot of the gauge troubles with the electronic dash is because the cluster has lost conection. You should be able to find out how to pull the cluster with an online search for instructions.
Re: Dads Magnum tach quit [Re: stumpy] #847318
11/06/10 04:41 PM
11/06/10 04:41 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
After an hour of google search, this is a major problem... But at least Dodge isn't standing behind their product as usual!!!
Re: Dads Magnum tach quit [Re: da50r] #847319
11/06/10 05:27 PM
11/06/10 05:27 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Sounds like high resistance, bad connections..
Find the connector from the computer to the dash, detach and kleen..
Doesn't take much a little moisture/oxidation will corrupt the connections..
Just my $0.02...
Re: Dads Magnum tach quit [Re: Sinitro] #847320
11/07/10 12:58 AM
11/07/10 12:58 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
My dealer buddy finally called me back. He said that the gauge goes bad, and this is a real rash of a bad part. Said they can be fixed for a few hundred bucks, or throw a junkyard one in and let it die too... Thats too bad...
Re: Dads Magnum tach quit [Re: da50r] #847321
11/07/10 05:18 AM
11/07/10 05:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
60,000 miles and you think Dodge should replace it for you ? What kind of warranty you have ? Ron
Re: Dads Magnum tach quit [Re: 383man] #847322
11/07/10 11:27 AM
11/07/10 11:27 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Head over to the LX Forum.com . . . always good information there, might even suggestions on this issue . . .
Cheers
Mark
