Re: Dads Magnum tach quit
[Re: da50r]
#847319
11/06/10 05:27 PM
11/06/10 05:27 PM
Posts: 5,444 So Cal
Sinitro
So Cal
2005, Hemi, loaded. 60,000 miles, and the tach stopped for no reason. Stealership said $900 to replace the cluster. Anything make sense here?
Sounds like high resistance, bad connections.. Find the connector from the computer to the dash, detach and kleen..
Doesn't take much a little moisture/oxidation will corrupt the connections..
Just my $0.02...
[Re: da50r]
#847321
11/07/10 05:18 AM
11/07/10 05:18 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
After an hour of google search, this is a major problem... But at least Dodge isn't standing behind their product as usual!!!
60,000 miles and you think Dodge should replace it for you ? What kind of warranty you have ? Ron
