Priming 440 for Starting #846496
11/05/10 01:22 PM
11/05/10 01:22 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I am going to fire up a fresh 440 tomorrow. I want to prime the oil pump, but which way does the drill go to turn the rod? is it reverse?
RS23L7 4-Speed
Re: Priming 440 for Starting [Re: Mopar_Mike] #846497
11/05/10 01:23 PM
11/05/10 01:23 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
counter clockwise
Re: Priming 440 for Starting [Re: superbyrd] #846498
11/05/10 05:34 PM
11/05/10 05:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yup, counter-clockwise. Have a helper run the drill while you turn the crank over slowly to get the juices flowing.
Re: Priming 440 for Starting [Re: Mopar_Mike] #846499
11/05/10 05:46 PM
11/05/10 05:46 PM
be sure and hand turn it to reach the (2) seperate points in the crank rotation where each heads' passage lines up so they get prelubed also. May I suggest several helpers: 1 to add fluid to the trans when it starts, 1 to man the dist/timing light/1 down below to check for leaks/1 up top to check for fuel/coolant leaks. You in the drivers seat to keep the rpm's up/rev it/shout orders. Stat OUT. Front end jacked up as HIGH as you can get it (air pockets). Read "breakin secrets" CRITICAL. at www.mototuneusa.com (5 minute read). Turn timing marks to 10 BTDC #1 compression & set dist so w the can roughly where you want it & it has room to be turned & where a reluctor vane is dead even w the magnet & rotor under or nearly under cap terminal w #1 plug wire. Dist holddown snugged so it is tight but can be turned by hand to time it when it starts(to 36 w vac adv disconnected). Wired 18436572 CCW as said. Fill carb bowl vent w a turkey baster & 3 or 4 pumps of the AP to prime it. MAKE sure all systems are GO so it will light off immed. Proper breakin oil w zinc. Lifter bottoms (only) & lobes coated w the black moly paste & #1. Did I say #1: On prior mockup clean lifter bores w brake kleen & lightly lube each bore & it's lifter w WD40 & raise each lifter off of it's respective lobe & let it go & it should fall back on the lobe w a resounding "thunk" & if not the lifter bores are too tight and the lifter will not rotate properly & early cam failure will very likely result. Light honing to correct it. (hope yours are good w tomorrow being the big day). If solids I adj them then pull the shafts/pushrods & THEN lube the lobes/lifter bottoms then replace the rocker assy's as the adjustment will not change just from a R&R & lubing the cam 1st then alot of hand turning to adj valves will wipe too much lube off. A bit picky but w the current cam probs you dont want to take any chances there. Any leaks or probs cut it fast w no hesitation/fix them/start over. Rear wheels slightly off the ground & start in in drive so the eng has a load from the drivetrain. EDIT take out the inner springs w an on eng valve spring compressor & as you know no less than ~2500 rpm for ~25 minutes & VARY the rpm
Re: Priming 440 for Starting [Re: RapidRobert] #846500
11/05/10 10:42 PM
11/05/10 10:42 PM
Danville, NH
Danville, NH
Thanks, that's a lot of info, but good info!
RS23L7 4-Speed
Re: Priming 440 for Starting [Re: Mopar_Mike] #846501
11/05/10 11:43 PM
11/05/10 11:43 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
Make sure the oil pressure sending unit is installed. DAMHIK
Re: Priming 440 for Starting [Re: CYACOP] #846502
11/06/10 09:51 AM
11/06/10 09:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree make sure the OP gauge is hooked up.That or a plug in it if its on a stand.I didnt when I did my 440.Couldnt believe it got oil pressyre so fast.Make sure you have a good drill also.I used a 1/2 inch one and it dragged it down .Rocky
Chrysler Firepower
Re: Priming 440 for Starting [Re: therocks] #846503
11/06/10 12:35 PM
11/06/10 12:35 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
X2. I have seen drills start to smoke while priming an engine.
Re: Priming 440 for Starting [Re: GomangoCuda] #846504
11/06/10 04:28 PM
11/06/10 04:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
And break your wrist if not ready and holding on....lol
