A833 Mainshaft #846084
11/04/10 08:55 PM
11/04/10 08:55 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Need an A833 expert. I have a mainshaft with pitting on the nose piece. Should it be replaced repaired or is it good as is??
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: A833 Mainshaft [Re: 19cuda73] #846085
11/04/10 08:58 PM
11/04/10 08:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Picture would be helpful, but the shaft sounds like junk to me.
Re: A833 Mainshaft [Re: Challenger 1] #846086
11/05/10 12:20 AM
11/05/10 12:20 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Pic of mainshaft.
Re: A833 Mainshaft [Re: 70mopes] #846087
11/05/10 01:05 AM
11/05/10 01:05 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
I'd replace it. Years ago, I had the main ball bearing in the box fail, and damaged that nose. Some machine shop talked me into "putting a hard sleeve on the nose of the mainshaft, better than new."
Ya, right. NEXT time the "hardened ring" failed, took out the cluster/ pinion and a couple of other things.
That nose has a LOT of stress on it in any gear except 4th. It takes the side load of the gears 1, 2, 3. You won't feel or hear it until it's too late.
Re: A833 Mainshaft [Re: Yancy Derringer] #846088
11/05/10 10:43 AM
11/05/10 10:43 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Dont scrap it, wish I could find some.
save and put on shelf, sell or repair.
Re: A833 Mainshaft [Re: theclutcher] #846089
11/05/10 04:11 PM
11/05/10 04:11 PM
MN
astrobuf Offline
astrobuf  Offline
MN
This is fixable.
They way it should be done is to have the pitting ground off and hard chrome plated to build up the diameter and then ground to finish. You'd likely only remove .001 - .002" so no impact on load ability.
Cutting the nose down and sliding on sleeve would take too much stock off the nose and leve you exposed to fatigue stress.
Astrobuf
So, are you really a Rocket Scientist?
Re: A833 Mainshaft [Re: 19cuda73] #846090
11/05/10 09:31 PM
11/05/10 09:31 PM
IMGTX Offline
IMGTX  Offline
I'm leaning towards toast but if anyone can fix/save it it would be Brewers or Passon Performance.
If they say they can fix it it would be fixed right.
Re: A833 Mainshaft [Re: IMGTX] #846091
11/05/10 11:05 PM
11/05/10 11:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually these people are better at it and it will probably cost you less.
http://www.libertysgears.com/
Re: A833 Mainshaft [Re: 62maxwgn] #846092
11/06/10 10:32 AM
11/06/10 10:32 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
2nd that.
Weld and turn if dia too small.
