A833 Mainshaft
#846084
11/04/10 08:55 PM
11/04/10 08:55 PM
Posts: 1,300 Washington
19cuda73
Washington
Need an A833 expert. I have a mainshaft with pitting on the nose piece. Should it be replaced repaired or is it good as is??
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: A833 Mainshaft
[Re: theclutcher]
#846089
11/05/10 04:11 PM
11/05/10 04:11 PM
Posts: 654 MN
astrobuf
MN
This is fixable.
They way it should be done is to have the pitting ground off and hard chrome plated to build up the diameter and then ground to finish. You'd likely only remove .001 - .002" so no impact on load ability.
Cutting the nose down and sliding on sleeve would take too much stock off the nose and leve you exposed to fatigue stress.
Astrobuf
So, are you really a Rocket Scientist?
