Input on launch, video attached #845503
11/04/10 12:33 AM
11/04/10 12:33 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I finally got out again and hit Cecil for the N/A shootout. Someone video taped one of my launches so I can finally see how the car is reacting. I have new rear shocks and they seemed to be at the best setting. Front shocks are older and I could use a better converter. Tires don't seem to spin but I can't get the front end up and my 60's are too high. Best 60ft was 1.382. Any input for getting a better hook? I went to a 33" tire from 32" and kept 4:56 gears. I don't think I have any tire spin but just can't get it up on the tire. Will a new converter tailered to this engine and some new front coil overs get the front to lift or do I need to also change the rear gears? Hope this youtube video loads ok.
http://www.youtube.com/watch?v=B0PmN1kCT8s
Re: Input on launch, video attached [Re: Big_Fish] #845504
11/04/10 12:44 AM
11/04/10 12:44 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i think it looks good,ask 1badfish about wheelies,he's on his 3rd oil pan in one yr..lol sorry pablo
Re: Input on launch, video attached [Re: fishy340] #845505
11/04/10 05:34 AM
11/04/10 05:34 AM
Q
Quicktree Offline
Quicktree  Offline
Q
couldn't really see the tires but it looked good from what I seen my car launches about the same.
Re: Input on launch, video attached [Re: Quicktree] #845506
11/04/10 07:20 AM
11/04/10 07:20 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
did you leave at an idle????
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Input on launch, video attached [Re: Big_Fish] #845507
11/04/10 08:10 AM
11/04/10 08:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Your front end is not reacting much at all?? looks like it only has about 1 to 1 1/2" of suspension travel!
Are the shocks super tight against separation?
Does not look like it spins!
But I'm no expert.
Re: Input on launch, video attached [Re: Dodgem] #845508
11/04/10 02:36 PM
11/04/10 02:36 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Difficult to see on the vid but it doesn't look like it's hitting the rear tyre hard, as has been said check the front suspension for movement didn't see much weight transfer at all. Looked like it was spinning to me, did it leave some stripes and caterpiller marks?
Need more info. Whats the set up ie 4 link, ladders, stock front? whats the 1/4 time and MPH?
Nice looking 'Cuda BTW, sits real nice
Re: Input on launch, video attached [Re: Tig] #845509
11/04/10 05:16 PM
11/04/10 05:16 PM
Finland
mafo Offline
mafo  Offline
Finland
sounds like converter problem to me, couldn t really hear much rpm drop when shifting to third
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Input on launch, video attached [Re: mafo] #845510
11/04/10 05:31 PM
11/04/10 05:31 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
A car running 1.3x 69ft times should really be pitch rolling. The car acts like it has no front suspension at all. It looks like it drive out of the launch on rails.
Front shocks would be the first thing to change.
Re: Input on launch, video attached [Re: Bob_Coomer] #845511
11/04/10 05:33 PM
11/04/10 05:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
not really if it doesn't have enough power to work the suspension. mine does the same exact thing. I have talked to Monte about this this and he agrees..
Re: Input on launch, video attached [Re: Big_Fish] #845512
11/04/10 05:41 PM
11/04/10 05:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heres a video of mine, 4 link car with strange double adjustble shocks on the rear just loose shocks on the front with about 5" of travel.
http://s579.photobucket.com/albums/ss238/Quicktree09/?action=view&current=SDC11213.flv
Re: Input on launch, video attached [Re: Quicktree] #845513
11/04/10 05:47 PM
11/04/10 05:47 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
convertor is a little "tight"--loosen it up-----
and get some more travel out of the frt shocks.
like to see more "lift" in the front end.
just an personal guess---without being right there to see the car up close and get some E.T. info
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: Input on launch, video attached [Re: mafo] #845514
11/04/10 09:43 PM
11/04/10 09:43 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
My thoughts too. Sounds like it has a governor on the motor....??? Sounded alittle funny in the water box...no RPM ...???
If you like drag racing, support your local track.
Re: Input on launch, video attached [Re: CHAPPER] #845515
11/04/10 11:41 PM
11/04/10 11:41 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I appreciate all the input Here's some more info... 4link, new strange rear double adjustable shocks, older front Alden adjustable, 5500 TCI converter from original motor. Car weighs 2880 with driver. Hoosier QTP 33x22.50 DOT slicks. I took measurements, jacked up the front end and measured again and I have 2 1/4in of total travel, magnumforce tubular front end. Times on that run were, 60ft=1.383, 330=4.10, 1/8th=6.424 at 105.92, 1000ft=8.421 1/4=10.105 at 134.11. Car just doesn't feel like it will transfer the weight off the front end and get out of the hole quick enough. New front shocks and a nice custom converter for this combo were put on the back burner but I'm wondering how much difference those changes will make since I'm ready to pull the trigger and crack open the wallet. Any miracles like several tenths out of this possible?
Re: Input on launch, video attached [Re: StripeHOG] #845516
11/04/10 11:43 PM
11/04/10 11:43 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Yes, I was leaving off idle didn't even get it up on the converter when I left. I have a trans brake but the car seems to like to leave better on foot brake.
Re: Input on launch, video attached [Re: Bob_Coomer] #845517
11/04/10 11:52 PM
11/04/10 11:52 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Exactly how it feels. It takes off but doesn't pitch roll like I would expect. The Alden shocks are probably the originals from the tubular magnumforce front end, they're that old. They are on the loosest setting. Not much space for the coil overs (about 12-13in) when static so I'm not sure what new coil over options I have to get the best travel without make the car sit high? Any recommendations? Should I stick with Strange like the rears I just put on for up front or is there a better selection specifically for this type of setup?
Re: Input on launch, video attached [Re: Big_Fish] #845518
11/05/10 10:40 AM
11/05/10 10:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd try and load the converter some..also it didn't sound like it flashed anywhere near 5500. And I did not see any wheel spin either.
Re: Input on launch, video attached [Re: Mr.Yuck] #845519
11/05/10 12:44 PM
11/05/10 12:44 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i agree on the power application and converter..
if you listen to the motor..it doesnt come up on top of the cam until 60ft..
you can hear the engine come to life about 50/60ft out..
you need to be able to leave closer to that power point..
a well sourced converter should do that..
Higher initial rpm (in the power range)launch with a different converter should help..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Input on launch, video attached [Re: Big_Fish] #845520
11/05/10 02:11 PM
11/05/10 02:11 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Picked up over 3 10ths with a custom converter (ATi) Best was 10.37 from a previous best of 10.71. We also added a windage tray at the same time too, what that contributed I don't know.
Tyres looked like they were cupping and or wadding going of the marks they left behind, anyone else notice?
Also did I hear a slight miss through the top?
ET looks a tad slow for the MPH to me but my car is a tank anyway
Re: Input on launch, video attached [Re: Tig] #845521
11/05/10 06:18 PM
11/05/10 06:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Have you double checked the 4-link settings, lots of variables, probably 1200+ positions only a few are correct.
Im not buying the "not enough power" excuse. I see lots of guys at many diff tracks getting up on the rear tires, some pulling some outstanding wheel stands at unbelievable low rpm's, at slower e/t's.
Im betting its i the adjustment and maybe the converter.
Re: Input on launch, video attached [Re: Bob_Coomer] #845522
11/06/10 03:38 PM
11/06/10 03:38 PM
sweden
sshemi Offline
sshemi  Offline
sweden
if it aint spinning why would you wanna adjust the suspension???
Replace converter and then start all over again.
