90 318 to soild lifters
#84525
07/05/08 07:24 PM
07/05/08 07:24 PM
i have a 90 318 hyd roller engine i just rebuilt and was center lineing the cam when i cheaked max valve lift it was only .301 lift at the lobe so 1.5 roller rockers 451 lift so this wount cut it. id like to put in one of my soild flat tapped cams in this engine.????????
Re: 90 318 to soild lifters
[Re: babarracuda]
#84527
07/05/08 08:33 PM
07/05/08 08:33 PM
well the block been 0 decked kb 167 flat tops i will later down the road put it in my volare wagon 3500 stall 727 410 gears victor intake ported j heads 1.5 crane rollers headers.ect but for next couple of mouths i going to in stall it in my drag car 2800# 727 4800 stall 486 gears 31 slicks in stall my w2s 1.5 harland sharps rollers victor w2 800 holley dp so thats way the hyd 451 cam would work. and im asking if i install the solid cam and lifters will i have oil pressure broblems. thanks
#84528
07/05/08 08:43 PM
07/05/08 08:43 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if your 318 oils thru the heads/shafts, you should not have any oiling problems going to solid lifters.
take a look and see if cam bearing #2 and #4 have holes in them to oil the heads...
you will probably need to change out the pushrods ....will need pushrods for adjustable rockers with solid cam....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#84529
07/05/08 08:49 PM
07/05/08 08:49 PM
yes it has head oiling to the rocker shafts.
#84530
07/05/08 09:53 PM
07/05/08 09:53 PM
[Re: goldmember]
#84532
07/06/08 10:15 AM
07/06/08 10:15 AM
any one???? im going to pull the hyd roller out and put in the soild and soild lifters thanks..
[Re: goldmember]
#84534
07/06/08 11:20 AM
07/06/08 11:20 AM
[Re: babarracuda]
#84536
07/06/08 01:04 PM
07/06/08 01:04 PM
no big deal but it is 1990 318 not a magnum
