90 318 to soild lifters #84525
07/05/08 07:24 PM
07/05/08 07:24 PM
Anonymous OP
Anonymous OP
i have a 90 318 hyd roller engine i just rebuilt and was center lineing the cam when i cheaked max valve lift it was only .301 lift at the lobe so 1.5 roller rockers 451 lift so this wount cut it. id like to put in one of my soild flat tapped cams in this engine.????????
Re: 90 318 to soild lifters #84526
07/05/08 08:06 PM
07/05/08 08:06 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
.451 lift is not that far off from real good for a 318. You cannot just drop in solid lifters on a hydraulic cam They are diferent grinds (solid vs. hyd). If you change to a bigger cam, you will probably just make it a real dog off the line. I put a 270 with .490 lift in my old 318 and it was slower off the line and I had 4.30 gears. What are you trying to accomplish? ( street, strip or both). What car, trans and rear end ratio?
Re: 90 318 to soild lifters [Re: babarracuda] #84527
07/05/08 08:33 PM
07/05/08 08:33 PM
Anonymous OP
Anonymous OP
well the block been 0 decked kb 167 flat tops i will later down the road put it in my volare wagon 3500 stall 727 410 gears victor intake ported j heads 1.5 crane rollers headers.ect but for next couple of mouths i going to in stall it in my drag car 2800# 727 4800 stall 486 gears 31 slicks in stall my w2s 1.5 harland sharps rollers victor w2 800 holley dp so thats way the hyd 451 cam would work. and im asking if i install the solid cam and lifters will i have oil pressure broblems. thanks
Re: 90 318 to soild lifters #84528
07/05/08 08:43 PM
07/05/08 08:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if your 318 oils thru the heads/shafts, you should not have any oiling problems going to solid lifters.
take a look and see if cam bearing #2 and #4 have holes in them to oil the heads...
you will probably need to change out the pushrods ....will need pushrods for adjustable rockers with solid cam....
Tony
70 AARCuda Vitamin C
Re: 90 318 to soild lifters [Re: 70AARcuda] #84529
07/05/08 08:49 PM
07/05/08 08:49 PM
Anonymous OP
Anonymous OP
yes it has head oiling to the rocker shafts.
Re: 90 318 to soild lifters #84530
07/05/08 09:53 PM
07/05/08 09:53 PM
Anonymous OP
Anonymous OP
Re: 90 318 to soild lifters #84531
07/05/08 10:00 PM
07/05/08 10:00 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yes, you can run solid lifters.
Re: 90 318 to soild lifters [Re: goldmember] #84532
07/06/08 10:15 AM
07/06/08 10:15 AM
Anonymous OP
Anonymous OP
any one???? im going to pull the hyd roller out and put in the soild and soild lifters thanks..
Re: 90 318 to soild lifters #84533
07/06/08 10:52 AM
07/06/08 10:52 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The only problem that I can see is trying to use the wide oil band 273 solid lifters. They will with many cams uncover the oil band making a big problem. Just install it and have a look.
Re: 90 318 to soild lifters [Re: goldmember] #84534
07/06/08 11:20 AM
07/06/08 11:20 AM
Anonymous OP
Anonymous OP
thanks
Re: 90 318 to soild lifters #84535
07/06/08 12:14 PM
07/06/08 12:14 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Sorry, I missed the cam & lifter part. The only issue is oiling and I am not a magnum block expert.
Re: 90 318 to soild lifters [Re: babarracuda] #84536
07/06/08 01:04 PM
07/06/08 01:04 PM
Anonymous OP
Anonymous OP
no big deal but it is 1990 318 not a magnum
Re: 90 318 to soild lifters #84537
07/07/08 09:38 AM
07/07/08 09:38 AM
scratchnfotraction Offline
you need the right push rod for solid
mags are hollow and shorter
