Low fuel level warning light #845252
11/03/10 06:35 PM
11/03/10 06:35 PM
West Palm Beach, Florida
Rockland71GTX Offline OP
I hope someone out there will have some info to help me out. I would like to add a low fuel level warning light to my 72 B body rally gauge cluster. I have been looking for a factory relay with no luck,and was hoping that I could build one with parts from Radio Shack. Does anyone have a schematic of the circuit in the factory relay? (Or a lead to a factory unit at a reasonable price?) Thanks!
Re: Low fuel level warning light [Re: Rockland71GTX] #845253
11/03/10 08:35 PM
11/03/10 08:35 PM
Castlegar, BC, Canada
That AMC Guy Offline
I have a spare one from an AMC Gremlin. It has a pentastar and a non-AMC part number on it. Pretty sure AMC sourced it from Chrysler. I'll see if I can dig it out. Couldn't tell you if it works or not though.
Weren't the low fuel lights in the overhead console on SE's? Never heard of one being in the gauge cluster.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Low fuel level warning light [Re: That AMC Guy] #845254
11/03/10 09:02 PM
11/03/10 09:02 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
The A02 driver aid group was an option on 71 GTX and Road Runners. The indicator light was located on the plate with the map light under the dash pad. I have this option on my RR. The relay is similar to the ones used on Gran Coupes, SE Challengers and a lot of C bodies, only difference was the mounting bracket.
Re: Low fuel level warning light [Re: That AMC Guy] #845255
11/03/10 09:23 PM
11/03/10 09:23 PM
I'm customizing a bit, so original parts/#'s don't matter, as long as it works! I want to put some yellow LED's around the gauge(hidden by the bezel) that will light up for low fuel.
Re: Low fuel level warning light [Re: spk2go] #845256
11/03/10 09:43 PM
11/03/10 09:43 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
The A02 driver aid group was an option on 71 GTX and Road Runners. The indicator light was located on the plate with the map light under the dash pad. ...
There are three indicator lights on the left side of the panel.
Re: Low fuel level warning light [Re: charger440sixpak] #845257
11/03/10 10:51 PM
11/03/10 10:51 PM
None
71rm23 Offline
71rm23  Offline
None
I've only seen the low fuel and fasten seat belts.
Re: Low fuel level warning light [Re: 71rm23] #845258
11/03/10 11:55 PM
11/03/10 11:55 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
the gauage was powered from the LFR ( low fuel relay) of the 5 volts-not from the existing one from the rest of the guages- the sender went into the LFR- there was a bit of electronics inside it.
so when the tank was around 1/4 full a circuit would turn on a relay inside and turn on the bulb.
Re: Low fuel level warning light [Re: 71_deputy] #845259
11/04/10 12:20 AM
11/04/10 12:20 AM
That's pretty cool. Does anybody have a pic of the relay itself? I'd like to compare it to my AMC ones.
Re: Low fuel level warning light [Re: That AMC Guy] #845260
11/04/10 01:50 AM
11/04/10 01:50 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
must to say IT WON'T WORK on 72 and lates UNLESS use plastic sockets kind ( some models had it with two blue wires ) to bulbs what makes a diff wires setup arriving to panel ( what doesn't exist, would be a custom harness )
WHY ? because on 71s, both lights are switched on by positive, for a while since 72 the seatbelt light is switched by negative and fuel light ( if existant ) will still be switched by positive.
Using the same metal housing where one wire is used by both lights and one wire metal sockets ( due being a common signal by chassis ) will short the panel on 72 and lates setup
Already analized all the system, and even I could make it to work ( got offered one complete setup, but I couldn't afford the price ) got that conclusion
would need to use plastic sockets and rewiring both to make it work safe, sending the correct signals to each bulb, isolating the sockets/bulb housing from any kind of information ( positive or negative )
Re: Low fuel level warning light [Re: NachoRT74] #845261
11/04/10 11:54 AM
11/04/10 11:54 AM
SF Bay Area, CA
SF Bay Area, CA
Re: Low fuel level warning light [Re: NachoRT74] #845262
11/04/10 12:26 PM
11/04/10 12:26 PM
None
71rm23 Offline
71rm23  Offline
None
NachoRT74-Is that relay mounted on the side of the glove box liner? Screwed in?
Re: Low fuel level warning light [Re: 71rm23] #845263
11/04/10 03:47 PM
11/04/10 03:47 PM
Valencia, España
Valencia, España
yes... screws going through the liner from inside the box
same piece what charger440sixpak is showing
as stated, YOU CAN MOUNT THEM DIRECTLY ON A 72 AND LATE without pay attention on some wiring mods going to sockets, and replace AT LEAST one of the sockets for the plastic one. Better if replacing both
Re: Low fuel level warning light [Re: 71rm23] #845264
11/04/10 07:18 PM
11/04/10 07:18 PM
SF Bay Area, CA
SF Bay Area, CA
Don't even ask me how long it took me to figure out where that little critter mounted... It was a combination of the spacing of the two pre-formed holes in the glove box liner and the curve in the relay mounting bracket that accounted for the 'ah-ha' moment...
I may not be good, but I am slow...
Re: Low fuel level warning light [Re: charger440sixpak] #845265
11/04/10 09:52 PM
11/04/10 09:52 PM
OK! I found my spare one. Had one NOS that I plan to use, and one used one.
Here's pics:
Re: Low fuel level warning light [Re: That AMC Guy] #845266
11/04/10 09:53 PM
11/04/10 09:53 PM
Pic 2: They are very similar. Almost guarantee it's the same part.
Re: Low fuel level warning light [Re: That AMC Guy] #845267
11/05/10 02:14 AM
11/05/10 02:14 AM
Valencia, España
Valencia, España
it is in fact same piece, just diff body application so the diff bracket to diff mounting down the dash... same as practically every electrical piece around
