Re: Low fuel level warning light
[Re: Rockland71GTX]
#845253
11/03/10 08:35 PM
11/03/10 08:35 PM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
I have a spare one from an AMC Gremlin. It has a pentastar and a non-AMC part number on it. Pretty sure AMC sourced it from Chrysler. I'll see if I can dig it out. Couldn't tell you if it works or not though.
Weren't the low fuel lights in the overhead console on SE's? Never heard of one being in the gauge cluster.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: spk2go]
#845256
11/03/10 09:43 PM
11/03/10 09:43 PM
Posts: 441 SF Bay Area, CA
charger440sixpak
SF Bay Area, CA
The A02 driver aid group was an option on 71 GTX and Road Runners. The indicator light was located on the plate with the map light under the dash pad. ...
There are three indicator lights on the left side of the panel.
[Re: charger440sixpak]
#845257
11/03/10 10:51 PM
11/03/10 10:51 PM
Posts: 2,592 None
71rm23
None
I've only seen the low fuel and fasten seat belts.
[Re: 71_deputy]
#845259
11/04/10 12:20 AM
11/04/10 12:20 AM
That AMC Guy
That's pretty cool. Does anybody have a pic of the relay itself? I'd like to compare it to my AMC ones.
[Re: That AMC Guy]
#845260
11/04/10 01:50 AM
11/04/10 01:50 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
must to say IT WON'T WORK on 72 and lates UNLESS use plastic sockets kind ( some models had it with two blue wires ) to bulbs what makes a diff wires setup arriving to panel ( what doesn't exist, would be a custom harness )
WHY ? because on 71s, both lights are switched on by positive, for a while since 72 the seatbelt light is switched by negative and fuel light ( if existant ) will still be switched by positive.
Using the same metal housing where one wire is used by both lights and one wire metal sockets ( due being a common signal by chassis ) will short the panel on 72 and lates setup
Already analized all the system, and even I could make it to work ( got offered one complete setup, but I couldn't afford the price ) got that conclusion
would need to use plastic sockets and rewiring both to make it work safe, sending the correct signals to each bulb, isolating the sockets/bulb housing from any kind of information ( positive or negative )
[Re: 71rm23]
#845263
11/04/10 03:47 PM
11/04/10 03:47 PM
NachoRT74
Valencia, España
yes... screws going through the liner from inside the box
same piece what charger440sixpak is showing
as stated, YOU CAN MOUNT THEM DIRECTLY ON A 72 AND LATE without pay attention on some wiring mods going to sockets, and replace AT LEAST one of the sockets for the plastic one. Better if replacing both
[Re: 71rm23]
#845264
11/04/10 07:18 PM
11/04/10 07:18 PM
charger440sixpak
SF Bay Area, CA
NachoRT74-Is that relay mounted on the side of the glove box liner? Screwed in?
Don't even ask me how long it took me to figure out where that little critter mounted... It was a combination of the spacing of the two pre-formed holes in the glove box liner and the curve in the relay mounting bracket that accounted for the 'ah-ha' moment...
I may not be good, but I am slow...
#845265
11/04/10 09:52 PM
11/04/10 09:52 PM
That AMC Guy
OK! I found my spare one. Had one NOS that I plan to use, and one used one.
Here's pics:
[Re: That AMC Guy]
#845267
11/05/10 02:14 AM
11/05/10 02:14 AM
NachoRT74
Valencia, España
it is in fact same piece, just diff body application so the diff bracket to diff mounting down the dash... same as practically every electrical piece around
