New Hemi carburetor recommendation needed!!! #845024
11/03/10 10:07 AM
11/03/10 10:07 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
If this post should go somewhere else let me know.
A buddy is putting the final touches on his new Hemi stroker and is looking for a 4bbl carburetor recommendation. Any suggestions would be appreciated. Below are the specs for the motor:
528 Hemi
10.2 to 1 commpression
568 lift intake
550 lift exhaust
256/256 duration at 50
110 lobe seperation angle
4.5 bore
4.150 stroke
So, what do you think????
BTW, the Challenger that is getting the hemi is a 5-speed with a 4.10 Dana.
Thanks!!!
1970 Dodge Challenger T/A
Re: New Hemi carburetor recommendation needed!!! [Re: jeff968] #845025
11/03/10 10:54 AM
11/03/10 10:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Coming soon!!!!
Re: New Hemi carburetor recommendation needed!!! [Re: Mr.Yuck] #845026
11/03/10 10:58 AM
11/03/10 10:58 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I would use the Holley hp 1000 with annular boosters . or any brand with annular boosters because they have great throttle response.
1969 Dodge Charger 1969 Dodge Superbee
Re: New Hemi carburetor recommendation needed!!! [Re: cjs69mope] #845027
11/03/10 11:35 AM
11/03/10 11:35 AM
Call John Dickey at AED in Richmond, VA ( google them) BEST carb shop in the USA for the $$$ They WILL sell you the best for the $$ period. I have used over 150 units from them and the service is second to none--quality is tops--please call him before you buy-
Re: New Hemi carburetor recommendation needed!!! [Re: ] #845028
11/03/10 09:43 PM
11/03/10 09:43 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Tunnel ram with 2 'tators
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New Hemi carburetor recommendation needed!!! [Re: hemi-itis] #845029
11/03/10 09:50 PM
11/03/10 09:50 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Stage V intake with 2 Quick Fuel Aluminum HP type Main body VS 750 with Annulars in the primary side only. They do not list them but they will make them right up for you
Re: New Hemi carburetor recommendation needed!!! [Re: ] #845030
11/03/10 09:51 PM
11/03/10 09:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My Eddy headed 500" wedge with 260* cam does real well with a 1050 Dom. You have more displacement, similar cam and better (Hemi) heads. I can't believe you would need less carb than me. Going from a 950 to this Dom, netted me over 1 mph in the 1/8. And the throttle response on the street is fantastic. Ask the carb builders what the different costs would be between the 4150 style and a Dominator.
Master, again and still
Re: New Hemi carburetor recommendation needed!!! [Re: jeff968] #845031
11/04/10 12:16 AM
11/04/10 12:16 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
My 528 Hemi is pretty close to yours in specs. I run an 850 mighty demon on mine, but found it was limiting on the dyno. By 5000prm, the 850 is starting to choke the motor.
Re: New Hemi carburetor recommendation needed!!! [Re: Paul_B] #845032
11/04/10 11:18 AM
11/04/10 11:18 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Thanks everyone for the input!!!
