New Hemi carburetor recommendation needed!!!
#845024
11/03/10 10:07 AM
11/03/10 10:07 AM
Posts: 4,051 Connecticut
jeff968
Connecticut
If this post should go somewhere else let me know.
A buddy is putting the final touches on his new Hemi stroker and is looking for a 4bbl carburetor recommendation. Any suggestions would be appreciated. Below are the specs for the motor:
528 Hemi 10.2 to 1 commpression 568 lift intake 550 lift exhaust 256/256 duration at 50 110 lobe seperation angle 4.5 bore 4.150 stroke
So, what do you think????
BTW, the Challenger that is getting the hemi is a 5-speed with a 4.10 Dana.
Thanks!!!
1970 Dodge Challenger T/A
Re: New Hemi carburetor recommendation needed!!!
[Re: Mr.Yuck]
#845026
11/03/10 10:58 AM
11/03/10 10:58 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
I would use the Holley hp 1000 with annular boosters . or any brand with annular boosters because they have great throttle response.
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#845027
11/03/10 11:35 AM
11/03/10 11:35 AM
Call John Dickey at AED in Richmond, VA ( google them) BEST carb shop in the USA for the $$$ They WILL sell you the best for the $$ period. I have used over 150 units from them and the service is second to none--quality is tops--please call him before you buy-
[Re: hemi-itis]
#845029
11/03/10 09:50 PM
11/03/10 09:50 PM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
Stage V intake with 2 Quick Fuel Aluminum HP type Main body VS 750 with Annulars in the primary side only. They do not list them but they will make them right up for you
[Re: ]
#845030
11/03/10 09:51 PM
11/03/10 09:51 PM
Posts: 12,114 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My Eddy headed 500" wedge with 260* cam does real well with a 1050 Dom. You have more displacement, similar cam and better (Hemi) heads. I can't believe you would need less carb than me. Going from a 950 to this Dom, netted me over 1 mph in the 1/8. And the throttle response on the street is fantastic. Ask the carb builders what the different costs would be between the 4150 style and a Dominator.
Master, again and still
[Re: Paul_B]
#845032
11/04/10 11:18 AM
11/04/10 11:18 AM
jeff968
Connecticut
Thanks everyone for the input!!!
