1970 340 Question #84461
07/05/08 03:46 PM
07/05/08 03:46 PM
Richland , Webster County,Ga
Bubba C Offline OP
Bubba C  Offline OP
Does any one know how many pounds of compression my 70 340 should have give or take when using a cylinder pressure gauge?
Thanks, Bubba
Re: 1970 340 Question [Re: Bubba C] #84462
07/05/08 04:02 PM
07/05/08 04:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Lots of different factors to give you a better idea of the range.
I know the engine guys will need to know:
What cam does it have?
Stock heads?
What pistons does it have?
Re: 1970 340 Question [Re: autoxcuda] #84463
07/05/08 04:39 PM
07/05/08 04:39 PM
Bubba C Offline OP
Bubba C  Offline OP
The engine has never been torn down. Its all factory.
Bubba
Re: 1970 340 Question [Re: Bubba C] #84464
07/05/08 04:59 PM
07/05/08 04:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The factory manual just lists the minimun at 110 with max variation at 40 psi.
I've got stock original pistons in my 68 340 with MP 761 mild cam (should be less than stock static compression. I got around 130-140 psi and it's a well worn motor.
IMHO, At least a leak down test needs to follow the compression test to determine a "rebuild or not" decision.
Another not too hard indication of inside worn engine parts: In a small block you can pull the lifters with just taking the valve covers and rocker arm rails off. That less than 20 bolts. Then you could look for worn lobes and beat valve tips.
Re: 1970 340 Question [Re: autoxcuda] #84465
07/05/08 05:05 PM
07/05/08 05:05 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Just checked my Son's, trying to isolate a miss, they were all between 140 & 150 psi. ('69 340 with stock pistons, X heads).
Re: 1970 340 Question [Re: GODSCOUNTRY340] #84466
07/05/08 05:11 PM
07/05/08 05:11 PM
Bubba C Offline OP
Bubba C  Offline OP
You guys will never believe this but my son and I just checked this one and it has 175 lbs per cylinder. It has 2.02 J heads.
Bubba
Re: 1970 340 Question [Re: Bubba C] #84467
07/05/08 05:33 PM
07/05/08 05:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bubba
Makes sense, they havea tighter (than aftermarket) overlap cam and high compression. Especially if it still has original type steel head gaskets.
Re: 1970 340 Question [Re: autoxcuda] #84468
07/05/08 05:38 PM
07/05/08 05:38 PM
Bubba C Offline OP
Bubba C  Offline OP
Heres my next question: It has a 4639sa carter carb...Is that factory and whats the cfm?
Bubba
Re: 1970 340 Question [Re: Bubba C] #84469
07/05/08 05:50 PM
07/05/08 05:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bubba
68-70 340 carter AVS carbs are accepted by most people as around 625 cfm.
google search: carter carb part numbers
or I think there is a list of part numbers on the moparts archieve section.
Did you just buy this car or something??
Re: 1970 340 Question [Re: autoxcuda] #84470
07/05/08 06:04 PM
07/05/08 06:04 PM
Bubba C Offline OP
Bubba C  Offline OP
Yes I just got my hands on it a couple days ago. Ive built a few but I never knew what the compression on stock 340's was suppose to be or any thing about the stock carbs.
Thanks for all the help guys! Maybe some times I can return the favor!
Bubba
Re: 1970 340 Question [Re: Bubba C] #84471
07/05/08 06:23 PM
07/05/08 06:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bubba
Cut us a deal when it goes up for sale.
Re: 1970 340 Question [Re: autoxcuda] #84472
07/05/08 06:47 PM
07/05/08 06:47 PM
Bubba C Offline OP
Bubba C  Offline OP
What is your definition of a deal?(on the 70 340) I have a 72 block and a 73 block both 30 over I'll take $250.00 each for them. I still havent been able to identify the carb. I know its a Carter but I dont know the cfm.#4639sa.
Re: 1970 340 Question [Re: Bubba C] #84473
07/05/08 06:55 PM
07/05/08 06:55 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
69 340 AT, AC carb.
Likely about 625cfm
So do I get a free 340 for answering the quiz???
Re: 1970 340 Question [Re: RobX4406] #84474
07/05/08 06:58 PM
07/05/08 06:58 PM
Bubba C Offline OP
Bubba C  Offline OP
GOOD ONE! I wish I could...
Re: 1970 340 Question [Re: Bubba C] #84475
07/05/08 07:36 PM
07/05/08 07:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sounded like this motor was attached to a car. What car is it in? Pics? Sounds like an interesting find.
Re: 1970 340 Question [Re: autoxcuda] #84476
07/05/08 08:13 PM
07/05/08 08:13 PM
Bubba C Offline OP
Bubba C  Offline OP
Heres the story: A guy called me because he knew I'm a MoPar man. He says I got an old Plymouth if you wanna look at it. I said sure. When I got there it was a rusted out 66 Fury 2 door. I raised the hood and saw a 4 barrell. I started checking closer...and what do ya know! A 70 340 in a fury! I bought the whole car and kept the engine and tranny...oh and the 742 case 3.23 Sure Grip! I think the engine came out of an E body.
