Re: 1970 340 Question
[Re: autoxcuda]
#84465
07/05/08 05:05 PM
07/05/08 05:05 PM
Posts: 2,530 God's Country Maryland
GODSCOUNTRY340
Just checked my Son's, trying to isolate a miss, they were all between 140 & 150 psi. ('69 340 with stock pistons, X heads).
[Re: Bubba C]
#84467
07/05/08 05:33 PM
07/05/08 05:33 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
You guys will never believe this but my son and I just checked this one and it has 175 lbs per cylinder. It has 2.02 J heads.
Bubba
Makes sense, they havea tighter (than aftermarket) overlap cam and high compression. Especially if it still has original type steel head gaskets.
[Re: Bubba C]
#84469
07/05/08 05:50 PM
07/05/08 05:50 PM
autoxcuda
So Cal
Heres my next question: It has a 4639sa carter carb...Is that factory and whats the cfm?
Bubba
68-70 340 carter AVS carbs are accepted by most people as around 625 cfm.
google search: carter carb part numbers
or I think there is a list of part numbers on the moparts archieve section.
Did you just buy this car or something??
[Re: Bubba C]
#84471
07/05/08 06:23 PM
07/05/08 06:23 PM
autoxcuda
So Cal
Yes I just got my hands on it a couple days ago. Ive built a few but I never knew what the compression on stock 340's was suppose to be or any thing about the stock carbs. Thanks for all the help guys! Maybe some times I can return the favor!
Bubba
Cut us a deal when it goes up for sale.
[Re: Bubba C]
#84475
07/05/08 07:36 PM
07/05/08 07:36 PM
autoxcuda
So Cal
What is your definition of a deal?(on the 70 340) I have a 72 block and a 73 block both 30 over I'll take $250.00 each for them. I still havent been able to identify the carb. I know its a Carter but I dont know the cfm.#4639sa.
Sounded like this motor was attached to a car. What car is it in? Pics? Sounds like an interesting find.
[Re: autoxcuda]
#84476
07/05/08 08:13 PM
07/05/08 08:13 PM
Posts: 264 Richland , Webster County,Ga
Bubba C
Heres the story: A guy called me because he knew I'm a MoPar man. He says I got an old Plymouth if you wanna look at it. I said sure. When I got there it was a rusted out 66 Fury 2 door. I raised the hood and saw a 4 barrell. I started checking closer...and what do ya know! A 70 340 in a fury! I bought the whole car and kept the engine and tranny...oh and the 742 case 3.23 Sure Grip! I think the engine came out of an E body.
