489 or 742 posi unit for street and strip #843943
11/01/10 10:47 PM
11/01/10 10:47 PM
Illinois
saukvillage Offline OP
Illinois
I have two posi units a 489 and 742. I would like to know the difference between the two and which one would be considerd the stronger or more reliable unit for street and strip.
Re: 489 or 742 posi unit for street and strip [Re: saukvillage] #843944
11/01/10 10:51 PM
11/01/10 10:51 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The 742 is the better of the two versions.
Re: 489 or 742 posi unit for street and strip [Re: Neil] #843945
11/01/10 10:55 PM
11/01/10 10:55 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
489 is most likely an auburn style (cone), the 742 an eaton posi style (clutch)....I haven't had a cone style last longer than about 10k miles before it went open....
if buying new, I'd get one of the eaton torsen style, unless you're using a very high torque motor and verrry sticky tires (aka slicks) and your suspension hooks.
2017 Grand Cherokee Overland
Re: 489 or 742 posi unit for street and strip [Re: Neil] #843946
11/01/10 11:18 PM
11/01/10 11:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
And a lot easier to set up
Gus
64 Plymouth Savoy
Dana 60
Re: 489 or 742 posi unit for street and strip [Re: fourgearsavoy] #843947
11/01/10 11:54 PM
11/01/10 11:54 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Gus
Use a crush sleeve eliminator and the 489's are just as easy.
Re: 489 or 742 posi unit for street and strip [Re: RobX4406] #843948
11/02/10 09:54 AM
11/02/10 09:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gus
But it will still have the POS sure grip
Re: 489 or 742 posi unit for street and strip [Re: JohnRR] #843949
11/02/10 10:33 AM
11/02/10 10:33 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Gus
Not necessarily. As you know the sure grips are interchangeable between all cases and a lot have been changed over or it can be easily changed over.
Re: 489 or 742 posi unit for street and strip [Re: MoparforLife] #843950
11/02/10 10:55 AM
11/02/10 10:55 AM
P
Paul_Fancsali Offline
P
Back in the 60-70s Mopar mechanic's use to say the 742 clutch sure grip was junk and the cone lasted forever !Well 45 years later I'm finding they don't last forever but frankly after that long who cares? I'm using cone one that on its way but when it goes for good I'll replace it.
Re: 489 or 742 posi unit for street and strip [Re: Paul_Fancsali] #843951
11/02/10 12:34 PM
11/02/10 12:34 PM
USA
b54406barrel Offline
USA
Good to know I've got 5 years left! I've been beating the crud out of the 6bbl car 489 for 40 years.
Re: 489 or 742 posi unit for street and strip [Re: b54406barrel] #843952
11/04/10 07:26 PM
11/04/10 07:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do like I did as when the sure grip goes south put a Detroit Locker in it. Ron
Re: 489 or 742 posi unit for street and strip [Re: 383man] #843953
11/04/10 07:30 PM
11/04/10 07:30 PM
michigan woods
imfixinmopars426 Offline
michigan woods
if ring gear bolts are on same side as diff bolts its a cone,different sides its a clutch type,use the clutch in either cases,cones suck.
Re: 489 or 742 posi unit for street and strip [Re: imfixinmopars426] #843954
11/04/10 07:54 PM
11/04/10 07:54 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
ANYONE ever try the AIR-locker ?
Re: 489 or 742 posi unit for street and strip [Re: dOoC] #843955
11/04/10 10:20 PM
11/04/10 10:20 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
iv put in serveral arb air lockers..they are more of a off road locker, and less like a limited slip, meaning when they are locked they arelocked! if replacing id recomned a detroit true trac, the street manners of an open rear but locks up under slip...its alot better than a stock suregrip hands down
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
