Re: 489 or 742 posi unit for street and strip
[Re: Neil]
#843945
11/01/10 10:55 PM
11/01/10 10:55 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
489 is most likely an auburn style (cone), the 742 an eaton posi style (clutch)....I haven't had a cone style last longer than about 10k miles before it went open....
if buying new, I'd get one of the eaton torsen style, unless you're using a very high torque motor and verrry sticky tires (aka slicks) and your suspension hooks.
[Re: RobX4406]
#843948
11/02/10 09:54 AM
11/02/10 09:54 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
The 742 is the better of the two versions.
And a lot easier to set up Gus
Use a crush sleeve eliminator and the 489's are just as easy.
But it will still have the POS sure grip
[Re: JohnRR]
#843949
11/02/10 10:33 AM
11/02/10 10:33 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not necessarily. As you know the sure grips are interchangeable between all cases and a lot have been changed over or it can be easily changed over.
[Re: Paul_Fancsali]
#843951
11/02/10 12:34 PM
11/02/10 12:34 PM
Posts: 3,054 USA
b54406barrel
USA
Back in the 60-70s Mopar mechanic's use to say the 742 clutch sure grip was junk and the cone lasted forever !Well 45 years later I'm finding they don't last forever but frankly after that long who cares? I'm using cone one that on its way but when it goes for good I'll replace it.
Good to know I've got 5 years left! I've been beating the crud out of the 6bbl car 489 for 40 years.
[Re: BeEtLeJuIcE !]
#843955
11/04/10 10:20 PM
11/04/10 10:20 PM
Posts: 4,872 connecticut
pnypwr
connecticut
iv put in serveral arb air lockers..they are more of a off road locker, and less like a limited slip, meaning when they are locked they arelocked! if replacing id recomned a detroit true trac, the street manners of an open rear but locks up under slip...its alot better than a stock suregrip hands down
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
