Fuel pump question #843519
11/01/10 01:50 PM
11/01/10 01:50 PM
Clinton Twp, Michigan
DerickS Offline OP
DerickS  Offline OP
Has anyone ever run a electric fuel pump with a hi performance mechanical pump in the same system? Its on a mild bracket/street car, I have a BG HR220 and i'm looking for some security in a mechanical pump for long term driving or long trips. I dont want to get stranded with my electric pump. Any experience or opinions?
Re: Fuel pump question [Re: DerickS] #843520
11/01/10 02:11 PM
11/01/10 02:11 PM
NHRA used to require the stockers to run a mecahnical pump with a the electric pumps years ago. I ran a Holley blue pump with no regulator to a Carter NASCAR Hemi race mechanical pump on my M.W. stocker for years, no street use If your going to do that I would use the BG feul regulator before the mecahnical pump to make sure that the electric pump would not rupture the diaphram on the mechanical due to to high of inlet pressures of the BG pump. The BG HR pumps are designed to be a street pump, what are your worrys on running it by itself?
Re: Fuel pump question [Re: DerickS] #843521
11/01/10 02:38 PM
11/01/10 02:38 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Derick, you should be just fine with a high volume mech. Theres 1 (carter) that doesn't require a Reg. that puts out good volume, Mancini racing sells them, the one i'm useing does require a reg., this should be all the pump you'll need for even a mild stroker, hell i ran 12.5s with a house pump & never starved for fuel.
Here it is.
http://chucker54.stores.yahoo.net/cam6sumefupu.html
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Fuel pump question [Re: joedust451] #843522
11/01/10 04:09 PM
11/01/10 04:09 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Derick,
I noticed that on the 1-2 shift my pressure was down to about 1/2 psi with just the carter Hivol Mechanical, so I installed a cater electric to push the fuel to the mechanical pump, seems to be working fine.
I also ran this setup on my previous car for a couple of years with no problems.
Gary
Re: Fuel pump question [Re: Mr340] #843523
11/01/10 09:04 PM
11/01/10 09:04 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I've been running my car with the Carter electric that needs no regulator preset is 7lb i believe and feeds to a Carter Hi performance mech.Just lately i had noticed the pressure was too high and put a regulator on it but then i also just bought a new gauge and it showed it as too low.I think it ended up being a bad gauge.Just make sure you have a good hi po mech. pump and you'll be fine.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Fuel pump question [Re: DerickS] #843524
11/01/10 09:53 PM
11/01/10 09:53 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We ran a Carter hi vol mechanical pump(the one that doesn't use a regulator) with a Holley red out back.It worked great.
Nautilus Racing-
Re: Fuel pump question [Re: Chris2581] #843525
11/02/10 10:53 AM
11/02/10 10:53 AM
DerickS Offline OP
DerickS  Offline OP
Thanks for all the responses guys, it definately makes me feel better about running a tadem setup. After hearing a few of you I may eliminate the electric all together. Its reliability I'm after right now, I want to make it way more of a driver than a bracket car nowadays. Thanks again
Derick
