Re: Used 440 crank specs?
[Re: polkat]
#842396
10/31/10 01:16 AM
10/31/10 01:16 AM
Posts: 1,443 Maryland
Dads426
Maryland
Mains & Rods-Maximum out of round and/or taper: 0.001" from the '68 service manual.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: polkat]
#842398
10/31/10 01:57 AM
10/31/10 01:57 AM
RapidRobert
that figure'd be allowable for a stocker but not for a perf app. Not sure what the allowable is but it'd very likely be less than .001"
[Re: polkat]
#842401
10/31/10 05:09 AM
10/31/10 05:09 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
how much bearing clearance do you plan on? if you're clearances are tight, say, .0025, and you're out of round by .001, then you could see clearances as tight as .0015 on the mains...
**Photobucket sucks**
