Page 1 of 4 1 2 3 4
69 440 #841260
10/29/10 12:17 AM
10/29/10 12:17 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i just scored a 69' 440 long block, it was rebuilt by s&s remanfacting in Spokae WA, the guy i got it from never has installed it, it was still on the shipping crate and plastic, it has been oiled up and in good shape, i have no info with it, the guy i bought it from got it from a man who owed him some money, i have taken pics and have the number on the motor, can someone please give me the specs on this motor and also give me some good ideas how to care for this motor before i put in my car, also, it will be maybe 3mths before i can put in my car, how do i store this motor to keep the motor in good shape?
thanks
Re: 69 440 [Re: cornet684me] #841261
10/29/10 12:18 AM
10/29/10 12:18 AM
Brandon, Ms
Brandon, Ms
here is the date and the numbers on the side of the motor, does anybody have the specs by using only the numbers?
Re: 69 440 [Re: cornet684me] #841262
10/29/10 12:19 AM
10/29/10 12:19 AM
Brandon, Ms
Brandon, Ms
another
Re: 69 440 [Re: cornet684me] #841263
10/29/10 12:30 AM
10/29/10 12:30 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
Difficult to know the specs of a rebuilt engine: i.e overbore for rebuild, what cam, pistons etc...
For storage, a plastic bag and oil will keep it nice.
Re: 69 440 [Re: Paul_B] #841264
10/29/10 12:37 AM
10/29/10 12:37 AM
Brandon, Ms
Brandon, Ms
i was told that it was built back to factory specs, factory cam, i know the bore may be bigger , i was just wondering if i could get the specs, i mean, what auto this engine wld have come in, what horespower rating and factory compression ratio, may factory cam specs, is this possible?
thanks
Re: 69 440 [Re: Paul_B] #841265
10/29/10 12:40 AM
10/29/10 12:40 AM
Brandon, Ms
Brandon, Ms
i know this is probaly going to be stupid question, what kinda of oil and how do i put oil on the motor and where do i put the oil? and before i put in the car, is there anything that i need to do special? or just put in my car, prime the oilpump and also put in some break end oil?
Re: 69 440 [Re: cornet684me] #841266
10/29/10 12:43 AM
10/29/10 12:43 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
There's no way to tell what cam or pistons are in it now since it's been rebuilt? Hopefully, it still has the forged crank? Someone with experience can tell by looking at it. A machine shop could determine the specs on it but they probably have to remove one head. You can get some idea of what the original specs were if you post a photo of the top engine pad. It's the flat area to the right of the distributor on the drivers' side with numbers and letters stamped on it. It should at least say E440 with some other letters and numbers. You can get an idea of what body it came out of from the partial VIN stamped in the milled area on the bottom of the side of the motor on the passenger side (just above the oil pan rail).
Re: 69 440 [Re: cornet684me] #841267
10/29/10 12:50 AM
10/29/10 12:50 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
thanks
Look on the passenger's side for the full or partial VIN number. That may tell you the full VIN of the car or at least the plant where it was built. Then we can go from there.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 440 [Re: RoadRunnerJD] #841268
10/29/10 01:19 AM
10/29/10 01:19 AM
Brandon, Ms
Brandon, Ms
it has F440 stamped on the pad, then under this is the numbers 12 2 2
the number on the passenger side block above the oil pan is 0196614
Re: 69 440 [Re: cornet684me] #841269
10/29/10 02:14 AM
10/29/10 02:14 AM
Warrenton, VA
Warrenton, VA
It's a 1970 motor assembled Dec 22, 1969 with a factory rating of 350 horse power, probably out of a C body. I think the only difference are the cam, valve size and carbureation. It would have an HP stamped on the top engine pad if it came in a muscle car, What are the casting numbers on the heads?
Re: 69 440 [Re: cornet684me] #841270
10/29/10 08:27 AM
10/29/10 08:27 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
thanks
Doesn't matter what you were TOLD, it could have anything inside of it , first off unless it was rebuilt to factory 6pk specs there is NO EXACT replacement piston for a 440, I'd hazard a guess that the pistons in it are probably .100 below the deck and that's not a factory replacement piston for any 1970 440.
What you need to do is CALL the shop that rebuilt it and see if they can give you the info off the block , look for a tag or stamp of some sort .
Re: 69 440 [Re: JohnRR] #841271
10/29/10 05:16 PM
10/29/10 05:16 PM
New York
buck0123 Offline
buck0123  Offline
New York
would a C body have a hp2 block. On the top pad it has E440 wouldn't that be a 69 engine?
Re: 69 440 [Re: RoadRunnerJD] #841272
10/29/10 08:13 PM
10/29/10 08:13 PM
Brandon, Ms
Brandon, Ms
i will have to get the numbers on the head for you and get back to you, i know they are 906 heads, thats all i know
thanks
Re: 69 440 [Re: JohnRR] #841273
10/29/10 08:15 PM
10/29/10 08:15 PM
Brandon, Ms
Brandon, Ms
hey John, i have emailed the company and they are trying to find the build sheet, i sure hope they can, i wld just like having the specs, i plan on changing the cam anyway, i wld just like to have this info, thanks for your help, i will post the results once i have them
thanks
Re: 69 440 [Re: buck0123] #841274
10/29/10 08:17 PM
10/29/10 08:17 PM
Brandon, Ms
Brandon, Ms
hey Buck, it is really hard to see the stamping, i was thinking it was a f instead of e, i will have to look again tommorrow
thanks
Re: 69 440 [Re: buck0123] #841275
10/29/10 08:46 PM
10/29/10 08:46 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
thats roadrunnerjd's sample pic you're looking at not the one in question...
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: 69 440 [Re: cornet684me] #841276
10/29/10 10:56 PM
10/29/10 10:56 PM
Warrenton, VA
Warrenton, VA
thanks [/quote
It depends on what you want to do with it but with the 906 heads, it should run very strong in an every day street machine. Unless you expect to build an 11 second race car, I think it's likely to be a very good motor just with decent intake, ignition and the right carburation. With today's gas, you don't need 10.1:1 compression but my experience with the 68 and up blocks is that they will not generally have .100 deck height. The 67 blocks did because they had to keep the compression down with the small combustion chambers in the 67 and earlier heads. I would keep it in a controlled climate if possible but it won't rust too easily. It would be good if you could paint it, spray down the bare steel with some Mopar MP50 or equal and put a HD leaf bag over it to seal it up. It should be fine for months.
Re: 69 440 [Re: RoadRunnerJD] #841277
10/30/10 12:00 AM
10/30/10 12:00 AM
Brandon, Ms
Brandon, Ms
hey roadrunner jd, the casting number on the pass. head is 2848906, i hope this is right, was very hard to read, hope this helps to solve the puzzle
thanks
Re: 69 440 [Re: RoadRunnerJD] #841278
10/30/10 01:27 AM
10/30/10 01:27 AM
Brandon, Ms
Brandon, Ms
i am planning to bump up the cam to comp cam , extreme engery 274/286 230/236 .488/.491 110, 2800stall, holley 750 vac. sec., headers, ready to run dist., i have 3.55 sure grip, 2 1.2 dual exhaust, what do you think about this set up in my 68'dodge coronet R/T?
Re: 69 440 [Re: RoadRunnerJD] #841279
10/30/10 01:28 AM
10/30/10 01:28 AM
Brandon, Ms
Brandon, Ms
where do i get this Mopar MP50 oil? or can i use something i can get at the parts house?
thanks
Page 1 of 4 1 2 3 4
