Brake Line fitting thread size #84115
07/04/08 09:00 PM
07/04/08 09:00 PM
Port Orchard, Washington
Bad Boy Offline OP
Bad Boy  Offline OP
Does any body know what the thread size is for the front brake line fittings that go into the distribution block on a 68 Barracuda? I am trying to install a line lock and the kit came with a brass "T" fitting but the fittings on the brake lines are larger than the threads inn the "T" fitting. None of the adapters in the kit fit. I need to buy some adapter fittings but don't know what size to buy.
Re: Brake Line fitting thread size [Re: Bad Boy] #84116
07/05/08 07:41 AM
07/05/08 07:41 AM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
Sounds like you need a fitting reducer(maybe 1/4 female to a 1/8 male).check with your local hardware store.
