correct 1971 roadrunner gas cap #840513
10/27/10 09:15 PM
10/27/10 09:15 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I see there are several 'NOS' gas caps on ebay. what one would be the most correct for my 71 roadrunner built in march? thanks!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: correct 1971 roadrunner gas cap [Re: mopars_1] #840514
10/29/10 01:25 AM
10/29/10 01:25 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
anyone??
1937 Plymouth PT50
Re: correct 1971 roadrunner gas cap [Re: mopars_1] #840515
10/29/10 01:54 AM
10/29/10 01:54 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I dont know how correct those 'NOS' caps are,
but here is what a true NOS Chrysler in the box cap for your car looks like.
Actually in this case it's an NOS 'on' the box cap
Hope this helps.
Re: correct 1971 roadrunner gas cap [Re: mccannix] #840516
10/30/10 12:01 AM
10/30/10 12:01 AM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
1971 had two caps, the early (flat) one is in the photo above. The late (after Dec '71) cap hangs over the filler tube about 1 1/4" it's much thicker when you lay them flat. The caps do not interchange, I bought one from the auto parts store for $6 about a year ago.
Sorry, it should read after Dec '70. The filler neck is different because the deep cap would just spin, & not catch hold of the nubs. The car is a November built '71 Satellite equipped with N95.
Re: correct 1971 roadrunner gas cap [Re: gregn96cuda] #840517
10/30/10 12:17 AM
10/30/10 12:17 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
oh great, yet another mid year change.. my car was built in march 71. do you have a picture of the 'later' style one?? thanks!
-kevin
also, was this still a 2 pong cap or a 4 prong?
1937 Plymouth PT50
Re: correct 1971 roadrunner gas cap [Re: mopars_1] #840518
10/30/10 12:29 AM
10/30/10 12:29 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
the filler neck itself stayed the same though didn't it?
1937 Plymouth PT50
Re: correct 1971 roadrunner gas cap [Re: mopars_1] #840519
10/30/10 02:18 AM
10/30/10 02:18 AM
Shoreline, Washington
72roadrunnergtx Offline
Pretty sure, for the b-body, that mid-year gas cap and filler neck change was in Feb 72', for the 72' model year. The cap was redesigned with a safety catch, requiring a full 180 degrees of rotation to remove.
These are Stant branded caps, left; before Feb 72', right; after Feb 72'
