correct 1971 roadrunner gas cap
#840513
10/27/10 09:15 PM
10/27/10 09:15 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I see there are several 'NOS' gas caps on ebay. what one would be the most correct for my 71 roadrunner built in march? thanks! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: correct 1971 roadrunner gas cap
[Re: mopars_1]
#840515
10/29/10 01:54 AM
10/29/10 01:54 AM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
I dont know how correct those 'NOS' caps are, but here is what a true NOS Chrysler in the box cap for your car looks like. Actually in this case it's an NOS 'on' the box cap Hope this helps.
[Re: mccannix]
#840516
10/30/10 12:01 AM
10/30/10 12:01 AM
Posts: 1,225 El Cerrito Ca.
gregn96cuda
El Cerrito Ca.
1971 had two caps, the early (flat) one is in the photo above. The late (after Dec '71) cap hangs over the filler tube about 1 1/4" it's much thicker when you lay them flat. The caps do not interchange, I bought one from the auto parts store for $6 about a year ago.
Sorry, it should read after Dec '70. The filler neck is different because the deep cap would just spin, & not catch hold of the nubs. The car is a November built '71 Satellite equipped with N95.
[Re: gregn96cuda]
#840517
10/30/10 12:17 AM
10/30/10 12:17 AM
mopars_1
Ridgeland Wi
oh great, yet another mid year change.. my car was built in march 71. do you have a picture of the 'later' style one?? thanks! -kevin
also, was this still a 2 pong cap or a 4 prong?
[Re: mopars_1]
#840518
10/30/10 12:29 AM
10/30/10 12:29 AM
mopars_1
Ridgeland Wi
the filler neck itself stayed the same though didn't it?
