Any A&A Hemi cross ram users ? #840003
10/27/10 01:56 AM
10/27/10 01:56 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
I have a 472" Hemi and i am in need of a GOOD intake for it. i have tried the StageV 2*4 but it was a little dissapointing hp & tq wise. do not want to use scoop so any high rise intake is out of the question.(Had a Barton singleplane and with that the engine made 700hp). Moparīs cross ram wonīt fit under my hood. Now thinking those A&Aīs cross ramīs - alu or magnesium. has anyone used either one of those and what can you tell me about them ? Anyone dynoed their engine using one of those ?
Getting desperate with this intake question....
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840004
10/27/10 02:36 AM
10/27/10 02:36 AM
If the mopar cross ram doesnt fit, I doubt the a&a one will either.
Re: Any A&A Hemi cross ram users ? [Re: ] #840005
10/27/10 02:46 AM
10/27/10 02:46 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
i asked about it from Rick Allison (A&A transmission) and the ones they are making (64-65 race hemi cross ram) are 1.2" to 1.5" lower.
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840006
10/27/10 09:17 AM
10/27/10 09:17 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I have a 472" Hemi (Had a Barton singleplane and with that the engine made 700hp).
That is probably the best intake we have ever run next to an Indy tunnel ram on basically the same size engine. We have gone a non-hooking 11.1's in a 4010lb Charger with a pump gas hemi and that intake. You not likely to beat that one with a cross ram or any other single plane any time soon.
The Indy mod man dual 4 single plane intake or a Stage V dual four hollowed out into a single plane are really the only choices I see that you really have. Stay away from the M1....Its better left in the trunk.
Re: Any A&A Hemi cross ram users ? [Re: ] #840007
10/27/10 09:51 AM
10/27/10 09:51 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
A&A's cross ram will fit under your hood, it is a faithful reproduction of the originals. The Mopar Performance version with the bolt on lid is not the same and is taller causing hood amd firewall clearance issues with allot of cars.
As far as performance they've come a long way since the first cross rams were cast, pretty much any modern single plane dual 4 intake will out perform them all things being equal. It also depends allot on your engine and car combo, you can loose torque going from a dual plane, or just going from a shorter single plane to a taller one, you need to match all of the componants to get the most of whichever intake you choose.
Re: Any A&A Hemi cross ram users ? [Re: ScottSmith_Harms] #840008
10/27/10 10:16 AM
10/27/10 10:16 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
thanks guys,
you are givin me the advice I expected to get.
I do not think that all things being equal I can get the same power level with a 60īs style cross ram than with a modern (Barton high rise) intake.
i am just wondering if I can get the same power level with the cross ram with some internal changes.
I have upped the comp. from 10.5:1 to 11:1 and in the old version i used a solid cam and now there is somewhat bigger solid roller.
Question is what intake can handle it and still fits under the hood...
My car (ī69 Charger) is a street car.
i always hated the six pack scoop I had to use with the Barton intake.
The car went 11,5īs with that setup and that or better is my goal now also.
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840009
10/27/10 10:20 AM
10/27/10 10:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What was the HP difference with the Stage 5 ,also what carbs were you using and were they set up progressive or both opening at the same time ?
Re: Any A&A Hemi cross ram users ? [Re: JohnRR] #840010
10/27/10 11:07 AM
10/27/10 11:07 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
The hp difference was 40.
with the Barton intake there was a 1100 dominator and with the StageV there were 750 holleys and 800 Edelbrocks. both opening the same time. There was only a couple hp difference between the holleys and the edelbrocks.
With the holleys the fuel curve was significantly better in the dyno...
Also a bit confusing to us was that the peak power was with the Barton intake at 6800 and with the stageV at 6100 remembering that there is now a roller cam which should give itīs peak power way higher ??
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840011
10/27/10 11:17 AM
10/27/10 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the motor in the car ?
Re: Any A&A Hemi cross ram users ? [Re: JohnRR] #840012
10/27/10 11:52 AM
10/27/10 11:52 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
No, not before I am satisfied with it...
...and the car was recently painted and not yet completely assembled.
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840013
10/27/10 02:03 PM
10/27/10 02:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can't drive a dyno , if you don't want a scoop and it's a street car I really don't think you'll miss the 40 HP , are you comparing the entire dyno pulls or are you just stuck looking at the peak HP number ?
Re: Any A&A Hemi cross ram users ? [Re: JohnRR] #840014
10/27/10 02:37 PM
10/27/10 02:37 PM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
You are partly right i have to admit.
I may not notice those 40 hps in street and I do not race. i only go to strip to have some fun.
The loss of hp & trq was throughout the whole rpm range though and that I might feel and notice.
The cam was ordered from Barton (Cam Motion) to make more power not less. Ok, Barton propably would have known that when I change to that StageV intake that the power will not be what he suggested in the first place...i did not know either then that i am going to go this without scoop route....
Might be that i do not meet my goals with this setup but i just would not like to give up without trying...
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840015
10/27/10 03:53 PM
10/27/10 03:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are your goals ? 660HP is nothing to sneeze at , you'll have a hard time harnessing that on street tires and remember there will always be someone faster.
What did you tell Barton you were going to use for an intake and carb ?
Re: Any A&A Hemi cross ram users ? [Re: JohnRR] #840016
10/27/10 04:24 PM
10/27/10 04:24 PM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
I donīt recall we were talking about intakes with Barton when i ordered the cam so he propably thought that his intake will be used.
My goals ?
beat that 701hp that the engine made before.
Beat my 11,5 at the quarter.(it was with MHīs).
Go as fast as possible keeping the car really streetable, cruisable, etc.
Now, with Gear Vendors overdrive i hope it to be bearable in the highways too - little better mileage and less noice...
yes, there are and surely will be a couple faster guys than me.
Jyrki (is he still active here ?) with his double turbo Vip is in the 7īs in the street D class.
I guess I donīt beat him anytime soon...
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840017
10/27/10 05:27 PM
10/27/10 05:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My goals ?
yes jyrki is still here .
What was the 701HP combination ?
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840018
10/27/10 09:08 PM
10/27/10 09:08 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think you should evaluate the whole package.
First, if that Crossram fits under the hood I'm not so sure you will be able to run any type of air cleaner or velocity stack without compromising airflow and turbulence into the carbs.
660HP should put your heavy Charger into the 10's with suitable convertor, tires, suspension and gears.
I think the crossram looks cool but I'm not even sure it will eclipse the Stage V in performance.
Sheldon
Re: Any A&A Hemi cross ram users ? [Re: RUNCHARGER] #840019
10/27/10 10:04 PM
10/27/10 10:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Exactly, it's the combo that needs to be examined. Afterall consider that the same Hemi engine pictured below (stock appearing inline intake, etc.) propels a stock appearing 69 Road Runner wearing bias ply Redline tires into the 9's at nearly 140mph, it's his well matched total combo that gets it there, not just one componant.
Full Story On Dudeks Hemi Here
Re: Any A&A Hemi cross ram users ? [Re: ScottSmith_Harms] #840020
10/28/10 01:19 AM
10/28/10 01:19 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
JohnRR:
the combo was:
new mopar hemi block
mopar 4.125 crank
barton rods
JE 10.5:1 pistons
Barton ported heads
2.25/1.94 valves
Cam motion 262/264 .580/.560 mech.cam
Barton singleplane intake
1100 Dominator
With that Barton dynoed it at 701hp 622trq.
I drove it a couple thou miles and that 11.5/122 1/4 and then broke it....to this day noone is 100% sure what happened first - something broked or overrevved (there is a limiter) or what but a couple broken valves -> two pistons broken -> heads hurt...
Well, heads went back to Barton -> came back like new, excellent work.
new CP pistons 11:1
When it was "freshened" anyway I asked Barton to suggest me also a formula to more power ie. new cam.
New cam Cam motion roller is 256/260 .670/.648
Then i got the idea of no more scoop and here we are.Jyrki suggested me to go to dyno with that Barton intake to get the basic numbers of what the engine is actually capable to.
might do that the next time, but i would also like to have with me intake that I am going to use !
thats why I am asking about possible user comments about those cross rams to evaluete or even guess if I can use one !!
Sheldon:
You are absolutely right.
Barton told me in the first place that 10īs will come if my combo is otherwise figured out.
but, my main goal never was and stii isnīt only in the 1/4 mile. The car is really heavy with heavy duty suspension - nearer road race than dragstrip - this is not and never will be a full race car.
SottSmith:
Been twice visiting "you guys".
Once in carlisle and the last time we attained the Mopar nats. Saw Dudek and his car there and drooled all over it....
I have a whole lot of respect towards him (and several other fast guys too...who hasnīt ?).
I guess that those dudek numbers havenīt come easy or cheap ?
heīs done a whole lot of work to get there.
I am just starting my way to ehhh somewhere..
thatīs why I am asking help and read very carefully all your advice !
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840021
10/28/10 02:00 AM
10/28/10 02:00 AM
Helsinki,Finland
Hemi_K Offline OP
Hemi_K  Offline OP
Helsinki,Finland
one more thing we have tried.
We made our own intake.
took measurements of a Hogan cross ram and scaled it down.It worked and didnīt.came to a conclusion that making your own intake is not that easy...
First the numbers:
StageV was 662hp at 6300
574trq at 5300
Our own intake was 676hp at 6100
630trq at 4500
our own intake made more torq than the Barton intake !
those numbers where not what we hoped for.
We (ofcourse) hoped more hp and did not even expect to get that high trq numbers.
I would have used that intake to atleast drive the car one season to see how it actually works in the streets (and maybe in the quarter) but there were other issues.
That intake couldnīt distribute the fuel evenly.
it was near lean on some cylinders while fouling some plugs....
with more (how much ?) work and dyno time (how much ?) we guess it could be made to work but would it work properly ever is anyones guess.
to me it just told that in the engine there is potential with right intake !
Could it be the A&A cross ram ?????
Re: Any A&A Hemi cross ram users ? [Re: Hemi_K] #840022
10/28/10 07:22 AM
10/28/10 07:22 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
If you have hood clearance problems why not space the K memeber down a bit.Dave
