E Body Trans Crossmember. Need pictures
#839468
10/26/10 03:02 PM
10/26/10 03:02 PM
Posts: 2,648 GA
Boosted
GA
I have 2 at the shop and do not know which one to use..
Anyone have a pic of one so I will know which to use? Or I can take a pic of both of the ones I have..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: E Body Trans Crossmember. Need pictures
[Re: Boosted]
#839471
10/27/10 09:29 AM
10/27/10 09:29 AM
Posts: 2,826 NY usa
540challenger
NY usa
Need a little more info.
What year? They changed the bolt hoel spacign where it mounts to the tosion bar crossmember
Auto or manual?
[Re: 540challenger]
#839472
10/27/10 11:49 AM
10/27/10 11:49 AM
Posts: 2,648 GA
Boosted
GA
72 .. Car was a manual from the factory but now has a 727 to go in it. One of th eones I have, have an extra pc off the center of the mount and one just goes straight across..
I hate to put the motor and all in and not have the correct mount. I am a diabetic that is almost disabled now and doing duplicate work is not a good thing.
2011 RAM3500
[Re: Cudajon]
#839474
10/27/10 01:20 PM
10/27/10 01:20 PM
Posts: 2,648 GA
Boosted
GA
could you post it through the board? I am at work on the computer and our filter blocks the photo hosting sites...
2011 RAM3500
[Re: Boosted]
#839478
10/27/10 02:05 PM
10/27/10 02:05 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The one with the extra piece off the center is the correct one , automatic and std transmission have the mount location in the same place starting in 1970.
[Re: Boosted]
#839482
10/27/10 08:19 PM
10/27/10 08:19 PM
JohnRR
U.S.S.A.
This is the tranny mount from a 72 'Cuda. It will fit either a Auto or standard.
Tranny mount 1
Tranny mount 2
Just got home and that is the crazy mount I have...
What's so crazy about it ? that was the type of mount used on everything from either 71 or 72 up on rear wheel drive mopars cars .
[Re: 2fast4yourBrain]
#839486
06/02/14 05:06 PM
06/02/14 05:06 PM
Posts: 601 Mass
charge70
Mass
In 72,the trans mount crossmember changed part#'s,according to the parts book.By the parts book # the crossmember only fits 72,manual or auto,fitting B,J,R,W.. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
