Please help....Need trans decode!!!! #838583
10/25/10 02:09 PM
10/25/10 02:09 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
I have a 64 odge a100 that someone has fitted with a push button setup for the trans. I cannot figure out what the trans is...(2466091u1314572) is the number stamped on the trans.
If anyone could help that would be awesome, also need a park lever setup so I can put the truck in park, if anyone has ideas please let me know...
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck 1986 Power Ram 400hp 360 6" lift 1970 Plymouth custom suburban 318 4" drop 1996 Dodge 1500 360 4wd 3" lift North Central Indiana Mopar Club member
Re: Please help....Need trans decode!!!! [Re: swepty] #838584
10/25/10 03:08 PM
10/25/10 03:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I can't find that number in any of my sources but 1314 is the build date March 3, 1965 so it's a '65 transmission.
Re: Please help....Need trans decode!!!! [Re: John_Kunkel] #838585
10/25/10 03:15 PM
10/25/10 03:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look at the pan shape.I will either be a 904 or a 727.
Re: Please help....Need trans decode!!!! [Re: stumpy] #838586
10/25/10 05:40 PM
10/25/10 05:40 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I'm no expert on the A100s but the full size trucks used a pushbutton shifter until 1965. It had no park position. The parking brake was on the back of the transmission in those years.
Since the A100 came out in 1964 it could have had a dash lever transmission selector before the trucks. I can't locate a picture of a 64 A100 dash. Maybe it had the pushbutton shifter in 64. The only stock automatic used was the 727.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Please help....Need trans decode!!!! [Re: Soopernaut] #838587
10/25/10 05:52 PM
10/25/10 05:52 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
This one does have the seperate park cable, and no park position on the buttons. The buttons and bezel appear to be from a 58 lancer. This truck was originally a 3spd manual truck, that someone has converted and put this trans and setup into. That's why I cannot figure out what it is.
The a100's used a top trans mount and this trans does not have that type of mount, I had to make a cross member to go under the trans tail housing like a car.
Re: Please help....Need trans decode!!!! [Re: swepty] #838588
10/25/10 07:01 PM
10/25/10 07:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Your best bet is to find an original A100 dash shifter, they show up on e-bay occasionally.
If you choose to retain the pushbuttons you'll have to find a '62-'64 park mechanism and mount it to the dash. I had the same problem with my '57 NY that has a 727 and mounted the park mechanism under the dash.
Re: Please help....Need trans decode!!!! [Re: John_Kunkel] #838589
10/26/10 11:50 AM
10/26/10 11:50 AM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
I did find an a100 dash mount shifter, but my question now is will the push-button cable work hooked to a lever shifter? I know the park lock cable will, but not sure about the other.
The shifter I found is 250, and I don't want to buy it if it will not work. I have a shifter from a 68 a100 and it does not have the park lock cable provision, so it won't work. But the one on ebay will work if the cable will hookup and work right.
Re: Please help....Need trans decode!!!! [Re: swepty] #838590
10/26/10 12:40 PM
10/26/10 12:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is the Ebay shifter set up for two cables?
Re: Please help....Need trans decode!!!! [Re: stumpy] #838591
10/26/10 04:45 PM
10/26/10 04:45 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
Yeah the ebay shifter is setup for 2 cables. I just don't know if the lever shift and push button cables interchange.
I just bought (NEW) push button cable 325.00, and a (NEW) park lock cable 275.00. So I would like to use them...
Re: Please help....Need trans decode!!!! [Re: swepty] #838592
10/26/10 04:58 PM
10/26/10 04:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the transmission still has its '65 valve body the lever shifter will hook right up with the correct cables. Unfortunately neither of the new cables you purchased will work with the lever shifter, the shifter ends are different.
The correct '64-'65 dash shifter has provisions for two cables, if the dash shifter is setup for a single cable it's a '66 or later.
Re: Please help....Need trans decode!!!! [Re: John_Kunkel] #838593
10/28/10 10:53 PM
10/28/10 10:53 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
My cables have the ends that just have a flat area with a hole in it, like to go on a stud and then have a hairpin, or e-clip.
Would the actual travel of the cables be the same? I can make ends work as long as the actual shift cable won't bind when I go to the 'park' position.
Re: Please help....Need trans decode!!!! [Re: swepty] #838594
10/29/10 07:29 PM
10/29/10 07:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The cable core ends are different and so are the cable housing ends.
Pic of PB cable ends.
Re: Please help....Need trans decode!!!! [Re: John_Kunkel] #838595
10/29/10 07:30 PM
10/29/10 07:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Lever shifter ends.
Re: Please help....Need trans decode!!!! [Re: John_Kunkel] #838596
10/31/10 01:51 AM
10/31/10 01:51 AM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
OK, so I basically am stuck with the PB setup. I just need to get it adjusted and working smooth, then come up with a park lever setup of some type then?.?.
I will forego buying the lever shifter then since my PB cable is Brand New. Any suggestions on a lever setup for the park lock??? (that cable is new also)..
Re: Please help....Need trans decode!!!! [Re: swepty] #838597
10/31/10 03:15 PM
10/31/10 03:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look at my second reply above, there's a pic of the under-dash Park lever that operates the 2nd cable.
Here's a look at the insides robbed from a PB shift quadrant.
Re: Please help....Need trans decode!!!! [Re: John_Kunkel] #838598
11/03/10 12:22 PM
11/03/10 12:22 PM
Indiana
swepty Offline OP
swepty  Offline OP
Indiana
Looks nice, I think I will try to mimic that setup somewhat, since I am stuck with the cables I have.
Any ideas on how to adjust the PB stuff correctly?
