Big Block Water Pump Housing and Windage Tray? #838161
10/25/10 08:39 AM
10/25/10 08:39 AM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
Just wondering if anyone has had any experience with the Summit Racing aluminum housings? Also on the windage tray is the MP Performance sold okay quality? Do I even need one? Anyways, just building a very mild street 400 big block. TIA.
Re: Big Block Water Pump Housing and Windage Tray? [Re: OrangeProwler] #838162
10/25/10 10:52 AM
10/25/10 10:52 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Windage tray is free HP.Its not a necessity but is worth the $$$.The MP unit has to be modified.The Milidon one is a much better piece.I bought the MP and only used the gaskets.I installed the Milidon on my 440.It sees 7000 RPm all the time.Been together street driving for 3 years.Rocky
Chrysler Firepower
Re: Big Block Water Pump Housing and Windage Tray? [Re: therocks] #838163
10/25/10 10:56 AM
10/25/10 10:56 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
What he said , the MP tray returns the oil back to the pan slower , the milodon is a better piece.
Re: Big Block Water Pump Housing and Windage Tray? [Re: JohnRR] #838164
10/25/10 01:55 PM
10/25/10 01:55 PM
Middle of A Field
O
O
Middle of A Field
Thanks guys that confirms my concerns on the windage tray. Anyways, anyone know the quality of said aluminum water pump housing? Thanks in advance. Also, when removing the oil pan I'm assumming this also means I need to replace the front and rear main seals right? Sorry for the crazy question but, this is my 1st engine I am getting more hands on with.
Re: Big Block Water Pump Housing and Windage Tray? [Re: OrangeProwler] #838165
10/25/10 02:42 PM
10/25/10 02:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The front main seal is on the timing cover housing. Removal of the oil pan gives you access to the rear main seal cap but you don't HAVE to replace it when you pull the oil pan.
I run the MP windage tray, however I drilled a bunch of extra holes in it to aid in oil return kinda like the milodon pan.
Re: Big Block Water Pump Housing and Windage Tray? [Re: DaytonaTurbo] #838166
10/25/10 02:53 PM
10/25/10 02:53 PM
Middle of A Field
O
O
Middle of A Field
Thank you. Something else to add to my parts list.
Re: Big Block Water Pump Housing and Windage Tray? [Re: OrangeProwler] #838167
10/25/10 04:52 PM
10/25/10 04:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dont know about their housing as I run a super old MP housing.I do run the MP aluminum pump in it.Its been on 10 years and no problems.Rocky
Chrysler Firepower
Re: Big Block Water Pump Housing and Windage Tray? [Re: therocks] #838168
10/25/10 09:52 PM
10/25/10 09:52 PM
eastern long island,NY
JeepJimmy Offline
JeepJimmy  Offline
check with www.magnumhp.com
70 duster 360magnum, 1975 jeep j-10.
