Re: Exhaust Manifolds
[Re: bron_engines]
#836270
10/22/10 04:28 PM
10/22/10 04:28 PM
Posts: 5,163 CT
GTX MATT
CT
I know a guy running B body HP manifolds on a 440 in a '68 Dart. On the driver side the manifold comes awfully close to the steering column and cooks the nylon bushing in the end of it though.
[Re: GTX MATT]
#836271
10/22/10 04:37 PM
10/22/10 04:37 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
The column needs to be cut back to flush wit hthe firewall and the bushing moved up and it should be ok .
Since the OP has a low deck he could use the 68-69 C body HP manifold , it will work with a little creative pipe bending, I put one on my 383 with a factory BB K and I couldn't see any reason it would not work and wouldn't be any more restrictive than the factory manifold .
[Re: JohnRR]
#836273
10/22/10 10:10 PM
10/22/10 10:10 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
That's good to know.
