replacing fuel line/return line question #83482
07/03/08 12:22 PM
07/03/08 12:22 PM
Friendsville, TN
Reverend_Ron Offline OP
super street
super street
Friendsville, TN
1971 Charger.
I bought the one piece, pre-bent fuel line and return line.
Does the old one just twist out like removing a cork screw from a cork and the new one go in as smooth as a putting a dip stick in the dip stick tube?
Any info on this operation will be of great assistance prior to starting!!!
Also, do you take them out from the front or the rear?
In advance, THANK YOU!
68 Roadrunner, 383,4-spd 71 Superbee, Citron Yella, 383,slapstick 71 Charger 500, Autumn Bronze, 383,4-spd, A/C 72 Imperial, 2-dr hdtp 74 Charger SE, 440-auto, sunroof 84 Crew Cab Dually, 440-auto 01 Quad Cab Dually, HO Cummins;6-spd 08 H-D, Softail Custom 08 Challenger, 6.1 Hemi
Re: replacing fuel line/return line question [Re: Reverend_Ron] #83483
07/03/08 02:09 PM
07/03/08 02:09 PM
Andrewh Online content
Andrewh  Online Content
having a hard time understanding.
Twist out from where?
Re: replacing fuel line/return line question [Re: Andrewh] #83484
07/04/08 08:11 AM
07/04/08 08:11 AM
Friendsville, TN
super street
super street
Friendsville, TN
When replacing the fuel line and vapor line in my Charger - the ones that run from the engine bay to the fuel tank - is this a big project or is it pretty simple? I'm just not sure if there's many issues going THROUGH the frame or around and under the frame etc. And with the pre-bent ones, does it make it easier or harder with trying to "FISH" it through everything from front to rear?
Re: replacing fuel line/return line question [Re: Reverend_Ron] #83485
07/04/08 08:18 AM
07/04/08 08:18 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Once you get all the mounting screws out it is very easy. It only goes thru the frame in one place I beleive right by the torsion bar cross member.I would order prebent stuff. This is a 71 challenger before I added the third return line:
