8 3/4 Rear End Stamp ID - 7L27??? #834772
10/20/10 05:33 PM
10/20/10 05:33 PM
Oakville, Ontario, Canada
CDN72SE Offline OP
CDN72SE  Offline OP
Hi Guys,
Just doing some cleanup on my '72 318s rear-end, my question is what does the yellow "7L27" signify (bottom right picture)? I've read about the "489" case and the various coloured daubs but a search of the boards hasn't provided any answer. I'm not sure if I'm going to replicate it or not but I'm just curious as to it's meaning. I do not have a broadcast sheet... not sure if that would help things or not.
Any feedback would be greatly appreciated. When you've basically looked (and cleaned/replaced) at every piece of your car you start to want to know more about it.
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834773
10/25/10 05:54 PM
10/25/10 05:54 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Nobody knows?
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834774
11/25/10 02:31 PM
11/25/10 02:31 PM
CDN72SE Offline OP
CDN72SE  Offline OP
The gears are 2.76.
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834775
11/26/10 12:49 AM
11/26/10 12:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's obviously an ID stamp so the person assembling the rear end housing knew which chuck to install per some type of build order .
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: JohnRR] #834776
11/26/10 12:12 PM
11/26/10 12:12 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks John. Guess I need to come up with more exciting questions, lol.
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834777
11/26/10 12:26 PM
11/26/10 12:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Maybe get a Mod to move this to the resto section ?
