8 3/4 Rear End Stamp ID - 7L27??? #834772
10/20/10 05:33 PM
10/20/10 05:33 PM
Oakville, Ontario, Canada
CDN72SE Offline OP
CDN72SE  Offline OP
Hi Guys,
Just doing some cleanup on my '72 318s rear-end, my question is what does the yellow "7L27" signify (bottom right picture)? I've read about the "489" case and the various coloured daubs but a search of the boards hasn't provided any answer. I'm not sure if I'm going to replicate it or not but I'm just curious as to it's meaning. I do not have a broadcast sheet... not sure if that would help things or not.
Any feedback would be greatly appreciated. When you've basically looked (and cleaned/replaced) at every piece of your car you start to want to know more about it.
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834773
10/25/10 05:54 PM
10/25/10 05:54 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Nobody knows?
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834774
11/25/10 02:31 PM
11/25/10 02:31 PM
CDN72SE Offline OP
CDN72SE  Offline OP
The gears are 2.76.
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834775
11/26/10 12:49 AM
11/26/10 12:49 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's obviously an ID stamp so the person assembling the rear end housing knew which chuck to install per some type of build order .
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: JohnRR] #834776
11/26/10 12:12 PM
11/26/10 12:12 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks John. Guess I need to come up with more exciting questions, lol.
Re: 8 3/4 Rear End Stamp ID - 7L27??? [Re: CDN72SE] #834777
11/26/10 12:26 PM
11/26/10 12:26 PM
JohnRR Offline
JohnRR  Offline
Maybe get a Mod to move this to the resto section ?
