Low buck 318 build... #834556
10/20/10 09:42 AM
10/20/10 09:42 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Alright guys, I have a 66 Dart that is itching for attention...
It has a 318 from unknown orgins, w/ magnum heads, magnum version of a air-gap intake. Has great oil pressure, 155psi cranking compression, and runs hard from 3800-6200. But the stock converter and 2.9 rear gear make it an absolute slug on the bottom. I have a good built 904, 3500stall converter, 8 3/4 w/3.23 posi to throw in the rear. Has good suspension and been converted to disc brakes.
I live 44miles from work, around 85miles from the local track. I want to do a as cheap as possible build that I wouldn't have an issue driving to track and back. Pump gas deal.
I was thinking along the lines of: Factory exhaust manifolds swapped, homemade 2 1/4" crossover, cheap ebay t3/t4 hybrid (internally gated 8psi one), cheap ebay intercooler, blowthru 750 eddy, 3" downpipe split to 2 1/2"factory exits, bosch blowoff valve, msd 6al.
Thinking of putting the turbo where the battery would go and throwing the battery in the trunk.
Please crtique this.
Also as far as fuel systems go... can I use a carter mechanical pump or does it need to be boost referenced? I hate electric pumps on muscle cars.
Any flaws in the plan?
Brian
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Low buck 318 build... [Re: F1Scamp] #834557
10/20/10 10:39 AM
10/20/10 10:39 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Your plan sounds good and you have to have some sort of boost reference to your fuel pump.
Re: Low buck 318 build... [Re: F1Scamp] #834558
10/20/10 10:40 AM
10/20/10 10:40 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
That turbo will be too small for that application.
Re: Low buck 318 build... [Re: Duner] #834559
10/20/10 10:44 AM
10/20/10 10:44 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
What about one of those t70's?
Re: Low buck 318 build... [Re: F1Scamp] #834560
10/20/10 10:50 AM
10/20/10 10:50 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd buy a S/C unit of a 5.0L mustang and make it work for your Dart. Probably score an entire set-up for around $15-1800. You can't flip sb mani's like a BB. You will have to custom make everything. Unless you have mad welding skills the S/C is going to be cheaper in the end.
Coming soon!!!!
Re: Low buck 318 build... [Re: F1Scamp] #834561
10/20/10 10:54 AM
10/20/10 10:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
easy those pumps have a small vent hole in the top or side. When I did my s/c'd 440 I taped a small tube in that hole and ran a line from the head unit to it. worked like a charm.
Re: Low buck 318 build... [Re: Mr.Yuck] #834562
10/20/10 11:12 AM
10/20/10 11:12 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Not interested in doing a s/c set-up. Why cant I swap the manifolds side to side?
Re: Low buck 318 build... [Re: F1Scamp] #834563
10/20/10 12:46 PM
10/20/10 12:46 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i have not done alot of reserch on turbod aplications but i think you want a MSD6btm instead of the 6AL, if you already have the 6AL i think you may be able to add the boostretard.
Re: Low buck 318 build... [Re: F1Scamp] #834564
10/20/10 01:04 PM
10/20/10 01:04 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
You can't flip BB manifolds either, as the manifolds will usually block the sparkplug holes.
Can't flip SB manifolds upside down due the non-symmetrical center port and the offset mounting bolts for teh end cylinder ports. I suppose a guy could make some 1" thick adapters, but it would take some work.
You can swap SB manifolds side-side but chassis fitment would need verified, especially in an early Abody. You will have to lose the PS though (if you have it) because the manifold will dump right where the pump is.
I have seen a high-mount PS pump on an early Dakota that might allow PS, but I've never verified.
Re: Low buck 318 build... [Re: 1Fast340] #834565
10/20/10 01:07 PM
10/20/10 01:07 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The 6BTM is a boost timing master. If you already have a 6AL I think there is an add-on BTM you can plug into it.
FWIW, I would probably NOT use a 3500 stall in such a light car for turbo use. Turbos like to be loaded up, so to speak, so a low-stall is reportedly better. Wouldn't use it for somethign I drove that far to work every day, either.
Based on your 6200 revs, is your cam too large? Turbos like small overlap/duration, the oppoosite of a cam that helps a NA engine rev high. You'll have to research that one further.
Re: Low buck 318 build... [Re: F1Scamp] #834566
10/20/10 01:21 PM
10/20/10 01:21 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
To go further on what some others have said:
Boost-referencing is not related to teh type of pump you use, it refers to increasing fuel system pressure 1:1 with boost so that you fuel delivery remains constant. Mandatory with any force-fed engine.
As Yuck mentioned, you can boost-ref a mechanical pump that way, otherwise boost-ref for an elec pump is typically done at the pressure regulator (if a bypass style). Can't boost-ref a dead-head regulator, I don't think.
Whatever pump you use, you must verify that you get enough fuel flow at max boost (either by engineerig specs, measuring into a bucket, or a gauge on the engine) otherwise you will run lean, and lean can quickly destroy a pressurized engine. Some pumps can supply sufficient flow at low pressure, but adding 10-15 psi addtional pressure on their outlet causes them to deliver insufficient flow.
Remember - pumps create flow, the system restrictions create pressure. A pump must be able to provide flow in the face of that pressure.
Re: Low buck 318 build... [Re: F1Scamp] #834567
10/20/10 01:33 PM
10/20/10 01:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you want to turbo it you will have to custom make headers or as mentioned flipflop the mani's and create some kind of set-up. Not sure what would be easier. I guess you might be able to get a set of shorty headers and mount them backerds. One problem is you don't have a ton of room in that engine bay so you will need the no matter what you do.
Re: Low buck 318 build... [Re: Mr.Yuck] #834568
10/20/10 02:01 PM
10/20/10 02:01 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
All I have in the Duster is a carter mechanical, and I don't plan on going faster than 11.9's tops in the 66.
I have a msd6btm, but I was thinking just welding the slots in the dizzy would be a more consistant answer.
I am not afraid of alittle and .
Is there a turbo you guys reccomend? I am willing to take chances on the ebay deals.
Re: Low buck 318 build... [Re: F1Scamp] #834569
10/20/10 02:48 PM
10/20/10 02:48 PM
Tolstoy, SD
turbo66valiant Offline
Tolstoy, SD
We have the hedman block huggers on our 318ci and welded dizzy slots. This is in a 69 Dart so you would have to trial fit the headers. Looks like there is room to spare. Also running the basic MP Ign. Single turbo w/ Garret T70. Later
Ryan
Turbo Slant 6 Valiant 10.74 @ 127.47 6.65 @ 107.80 http://www.youtube.com/user/turbo66valiant
Re: Low buck 318 build... [Re: turbo66valiant] #834570
10/20/10 05:36 PM
10/20/10 05:36 PM
Houston, Texas
Houston, Texas
You can use block headers like in the pic above and have the driver's side come around either the back or the front.
Another option, which is what I did, was use a set of stainless shorty headers for an A body application and swapped sides. A bracket was made to relocate the PS up ½ inch.
Re: Low buck 318 build... [Re: turbo66valiant] #834571
10/20/10 08:27 PM
10/20/10 08:27 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
That set-up fits with the factory k-member? Do the pipes go under it?
I figured I could find some manifolds that would miss most everything, if I have to make a mount for the alternator to move it so be it. Someone has had to have done this and knows what manifolds would work?
Re: Low buck 318 build... [Re: F1Scamp] #834572
10/20/10 09:12 PM
10/20/10 09:12 PM
Tolstoy, SD
Tolstoy, SD
Yes it fits the K-member and tucked as close as possible to the bottom of it. They could also be sent above it but the bigger oil pan was an issue. Alt relocate was no problem. Later
Ryan
Re: Low buck 318 build... [Re: turbo66valiant] #834573
10/20/10 09:51 PM
10/20/10 09:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ryan
looks good. Wonder if you could do the same w/ a BB B-body???
Re: Low buck 318 build... [Re: F1Scamp] #834574
10/21/10 08:55 AM
10/21/10 08:55 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
If you go to the turbomustangs site, do a search thru my posts (I'm Fury Fan there also). I started a thread on alternator relocation brackets and I think there are some links in there. There are a few smallblock relocation kits out there.
Re: Low buck 318 build... [Re: Fury Fan] #834575
10/23/10 08:17 AM
10/23/10 08:17 AM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
manifolds off a mag motor fit perfect in an a-body flipped side to side
- and i flipped my alt to the drivers side with out havin to buy or make special brackets..just a vise to flatten out the triangle piece and made just shortened the spacers
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
