Odd wheel bolt pattern #834230
10/19/10 10:14 PM
10/19/10 10:14 PM
FL
74-440Charger Offline OP
FL
Have a ford 9" that has a 5 X 5 1/4" bolt pattern and can't find wheels for it. Two of us measured it several times. Help
Re: Odd wheel bolt pattern [Re: 74-440Charger] #834231
10/19/10 10:18 PM
10/19/10 10:18 PM
That is probally out of a Lincoln or Mercury car May be difficult to find wheels for them How about changing the bolt pattern to 5x4.5 like stock Ford and Mopar
Re: Odd wheel bolt pattern [Re: Cab_Burge] #834232
10/19/10 10:28 PM
10/19/10 10:28 PM
FL
FL
See...that's why I love this site All I'd have to do is change the drums and axels right?
Re: Odd wheel bolt pattern [Re: 74-440Charger] #834233
10/19/10 10:30 PM
10/19/10 10:30 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
put strange or moser axles in it and problem solved forever.
Brian
Re: Odd wheel bolt pattern [Re: '72CudaRacer] #834234
10/19/10 10:52 PM
10/19/10 10:52 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If your combo doesn't require the strength of after market components why not re-drill the axles and drums for 4.5" pattern?
Doug
Re: Odd wheel bolt pattern [Re: 74-440Charger] #834235
10/19/10 10:58 PM
10/19/10 10:58 PM
Hard to say without seeing them, a lot of the early big pattern wheels and axles had really big center holes in them also Look twice, measure three times, change once
Re: Odd wheel bolt pattern [Re: Cab_Burge] #834236
10/19/10 11:48 PM
10/19/10 11:48 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
5 X 5 1/2" American Motors All 5 lug Jeep, All 2WD (Except 79-85 Eagle,Cherokee, Cherokee Chief) 42-86
5 X 5 1/2" Chrysler Imperial (Special HD) 54-66
5 X 5 1/2" Ford All 28-48
5 X 5 1/2" Ford Full size pickup and Vans 49-86
5 X 5 1/2" Mercury All 39-51
home of the
Sox and Martin Hemi Duster
Re: Odd wheel bolt pattern [Re: HEMIFRED] #834237
10/19/10 11:53 PM
10/19/10 11:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I don't know about 5 1/4 " , but I know some Lincoln and pick up truck were 5 3/4 and some Lincoln were 9 3/8ths ring gear.
28 spline , the centers would swap , but they had a companion flange as opposed to a normal yoke.
Re: Odd wheel bolt pattern [Re: tubtar] #834238
10/20/10 01:49 AM
10/20/10 01:49 AM
north battleford sask
9
93reefblue Offline
93reefblue  Offline
80-83? ford f100(very light duty trucks had 5x4.5.(even though a 9" rear) f150's had 5.5.
crown vic/60's stang/94 up stang/ranger have same pattern
Re: Odd wheel bolt pattern [Re: 74-440Charger] #834239
10/20/10 02:12 AM
10/20/10 02:12 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
sorry there are no 5 x 5.25 patterns.
I listed the 5.5" but failed to mention no 5.25
here's a chart with all the sizes made and in use today. as for the 5.25 sometimes it's just how you measure. Not trying to be a smarty but if you are getting 5.25 by measuring across the center to the farthest hole it is the wrong way. the pattern is derived by the measuring the diameter of the circle and then counting the number of studs or holes placed evenly around that circle.
http://www.rustynutscarclub.com/Lug_nuts.htm#5 X 5 1/2"
home of the
Re: Odd wheel bolt pattern [Re: HEMIFRED] #834240
10/20/10 10:40 PM
10/20/10 10:40 PM
moparx Offline
moparx  Offline
fred, i hate to be a naysayer, but my buddy had a 90-something t-bird with a [real close to] 5 1/4" bc. it was probably a metric measurement, but the wheels from his 76 "starskey" torino most definately were a tad bigger than the 'birds, butthe 'birds wheels were far smaller than a 5" and way bigger than a 4" bc., but were NOT 4 1/2.
Re: Odd wheel bolt pattern [Re: moparx] #834241
10/20/10 10:54 PM
10/20/10 10:54 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
THEY COULD BE 5 X 133.35 mm
OR 49 FORD TRUCK IS VERY CLOSE
home of the
Re: Odd wheel bolt pattern [Re: HEMIFRED] #834242
10/20/10 11:04 PM
10/20/10 11:04 PM
moparx Offline
moparx  Offline
i thimk 49 ford truck[1/2 ton] is 5 1/2"bc. the 'bird wheel was definately smaller than 4 1/2", so you most likely are correct with the 133.35mm pattern. remember the mm "tire size debacle" ford had for the mousetwange for a while? something like a something-376mm tire size??? nor 14" or 15" but 35345mm ?
Re: Odd wheel bolt pattern [Re: 74-440Charger] #2638924
03/30/19 06:23 PM
03/30/19 06:23 PM
Arkansas
E
EZEMUNY20 Offline
EZEMUNY20  Offline
E
Arkansas
I have a set of craiger ss wheels that have a 5 x 5 1/4 bolt pattern. I was looking online when I ran across this thread about the same thing
