Page 2 of 3 1 2 3
Re: Toyo slicks and front race tires. Buy one get one free! [Re: jcastle1] #833572
10/20/10 12:50 AM
10/20/10 12:50 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
What would you guys reccomend?
69 b-body 383 4-speed 4:10 gear
13.04 @110 with a street radial 285/70r15(spinning badly)(31" tall tire)
Now my current tire is a 275/60r15 they look a little small back there.(have not ran this size at track)28" tall
I have 8 in rims
should I run the 370070 (29.0x9.0x15)
or the 370280(30.0x09.0x15)
I will be buying one of these part numbers so keep it limited to these 2.
I'm not a die-hard racer,but would love to see my car run somewhere in the twelves.
I know that you should use the tallest tire you can get under there,but I felt that the 285/70r15 radials were too tall!
Thanks!
For what you're doing, I would go with a M/T 275 drag radial. I was running 11.70s with a 1.61 short time with that tire in a pump gas, street legal 3500-lb '64 fury. They were pretty consistent unless the track had water coming up through it.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Kevins493] #833573
10/20/10 09:16 PM
10/20/10 09:16 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Thanks,but I was looking at these 2 Toyo tires exclusively.
I'm a Toyo dealer and this is a smokin' deal,so I'm gonna either get the 29x9x15 or the 30x9x15,
Thanks,
John
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833574
10/20/10 09:23 PM
10/20/10 09:23 PM
NC
barracuda man Offline
NC
30 x 10.5 W. Very similar in size to the 29.5 x 10.5 M/T 3062. "Tread" is a little wider and the tyre surprisingly took a little more pressure than we usually run. It was around 1 1/2 to 1 1/4 lb more if IIRC. Ran with tubes, still think it could take more pressure maybe upto 14lb.
HTH's
I need that same size but I didnt see it listed on the Toyo website. Did they quit making it?
what did you find out on the 30x10.5w toyo and how much is it.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: barracuda man] #833575
10/20/10 09:47 PM
10/20/10 09:47 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Where are Toyo tires made ?
Re: Toyo slicks and front race tires. Buy one get one free! [Re: mloboda] #833576
10/20/10 10:11 PM
10/20/10 10:11 PM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
I think they are made in Japan.
The store I found did not have the discount & another Toyo store didn't even list the slicks. I am interested in the 27.5 front tires.
69 Charger RT
Re: Toyo slicks and front race tires. Buy one get one free! [Re: jcastle1] #833577
10/21/10 10:23 AM
10/21/10 10:23 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Thanks,
John
IMO, the 29.0x9.0x15 fits your combination better.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: jcastle1] #833578
10/21/10 01:13 PM
10/21/10 01:13 PM
Thanks,
John
If the bigger tire s will fit, bigger is always better on a slick. To a certian extent, a VW bug does not need 14x32x15 slicks with a VW 1600 CC motor
Re: Toyo slicks and front race tires. Buy one get one free! [Re: MR_P_BODY] #833579
10/21/10 02:57 PM
10/21/10 02:57 PM
Guitar Jones Online laugh2
Put some air in them things
EDIT
Looks like you could use a anti roll bar also
I tried the air pressure up and down from 7.5 and that seemed to work best. Although as I said at a good track I could probably run more.
I'll agree on the antiroll bar though. I had it leaving nice and level off the foot brake but when I use the transbrake it still leaves like that no matter how much preload I put into the top right bar.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: greenpigs] #833580
10/21/10 06:47 PM
10/21/10 06:47 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
I figured they were. I'll keep buying M/T and Goodyear tires made in the USA. Some Goodyears are not and I won't buy those either.
I guess I must be the last guy in America that doesn't think it's OK to keep buying foreign products while our manufacturing base is being destroyed. This frustrates me to no end.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: mloboda] #833581
10/21/10 07:36 PM
10/21/10 07:36 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
We're all on the same planet,and everybody has to eat.The computer your typing on was'nt made here,was it?
Thanks for all the replies,I decided on the 29.0x9.0x15 Toyo
John
Re: Toyo slicks and front race tires. Buy one get one free! [Re: jcastle1] #833582
10/21/10 08:41 PM
10/21/10 08:41 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
John
I'm sure all the workers at Goodyear and M/T are delighted with your choice, John.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833583
10/21/10 09:06 PM
10/21/10 09:06 PM
NC
NC
Did i mention BUY ONE GET ONE FREEEEE!
Never seen m/t / goodyear / or hoosier do that.
Times are hard every where.BUY ONE GET ONE FREE has my vote.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: mloboda] #833584
10/21/10 09:59 PM
10/21/10 09:59 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I'm a tire dealer and a dealer for Goodyear as well as Mickey Thompson,heck I have Mickey Thompson radials on my car now.We carry almost every brand out there.
They all put food on my table pal,even the Chinese tires!
Re: Toyo slicks and front race tires. Buy one get one free! [Re: jcastle1] #833585
10/21/10 11:43 PM
10/21/10 11:43 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
Should I feel guilty for buying the Michelins that have been on my F150 for the past 10 years?
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Mr. T] #833586
10/22/10 01:11 AM
10/22/10 01:11 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Got my two front 27.5x4.5 today. $170 shipped. Thats hard to beat.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833587
10/22/10 01:28 PM
10/22/10 01:28 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
If I'm correct, Mickey Thompson tyres were being made in England until recently
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833588
10/22/10 05:26 PM
10/22/10 05:26 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
M/T may have a plant in England but all my M/T have always been stamped MADE IN USA.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: mloboda] #833589
10/22/10 06:13 PM
10/22/10 06:13 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Could be that they were made for European market I was told that they were making M/T tyres at the Avon / Cooper tyre factory and it closed very recently.
Also I know certain Iron and Aluminium blocks are cast over here, though I'm not saying they will have "Made in USA" on them
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833590
10/28/10 11:31 PM
10/28/10 11:31 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Thanks for all the replies, I just received my 29x9.0x15 Toyo slicks from a company called Treadepot.com in Georgia.
I look forward to meeting some of you at Edgewater or tri-state in 2011 !
Re: Toyo slicks and front race tires. Buy one get one free! [Re: jcastle1] #833591
10/29/10 02:50 PM
10/29/10 02:50 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I went ahead and ordered a set of 14.5 x 32's for my roadster from the dealer listed in PA. It was easy as could be he must be getting alot of calls about them. He guessed that shipping would run about $30 per tire.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Page 2 of 3 1 2 3
