Page 1 of 3 1 2 3
Toyo slicks and front race tires. Buy one get one free! #833552
10/19/10 09:19 AM
10/19/10 09:19 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Just wanted to make sure you guys have seen this. A guy here bought several pair of 32x14 and loves them. They say they are really good tires, just trying to get their name out there. They dont make a rear in my size so I bought two fronts. Got 2 27x4.5 fronts for $148. Best part is its unlimited to how many you buy! Great deal.
Link:
http://www.treadzone.com/files/news/pdf/Toyo_Proxes_Drag_Slicks_Promotion.pdf
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833553
10/19/10 09:23 AM
10/19/10 09:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833554
10/19/10 09:32 AM
10/19/10 09:32 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
"Limited to NHRA members only"
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Dart1031] #833555
10/19/10 09:54 AM
10/19/10 09:54 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
That means NOTHING. Im not an NHRA member. All they asked me for was my debit card number..
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833556
10/19/10 10:36 AM
10/19/10 10:36 AM
Guitar Jones Offline
I've been running their 14.5x32's on my Scamp for over a year and I really like them. I'm buying another set now even those these are not worn out yet.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Guitar Jones] #833557
10/19/10 01:49 PM
10/19/10 01:49 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
FWIW we ran Hoosiers, M/T's for years. Had to buy Toyo's when we had difficulty buying the usual brands. Was a bit sceptical but I think they are a really good tyre, work well on our car and I'll use them again
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833558
10/19/10 03:55 PM
10/19/10 03:55 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
What size Toyo did you go with?
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833559
10/19/10 04:11 PM
10/19/10 04:11 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
30 x 10.5 W. Very similar in size to the 29.5 x 10.5 M/T 3062. "Tread" is a little wider and the tyre surprisingly took a little more pressure than we usually run. It was around 1 1/2 to 1 1/4 lb more if IIRC. Ran with tubes, still think it could take more pressure maybe upto 14lb.
HTH's
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833560
10/19/10 04:24 PM
10/19/10 04:24 PM
Toyo says the tires are designed to be ran without tubes.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Guitar Jones] #833561
10/19/10 04:34 PM
10/19/10 04:34 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
I did think that they are of a stiffer sidewall construction than Hoosiers or M/T and considered leaving the tubes out. At the track, we still had to run more pressure than I expected, even with the tubes. The more pressure we put in, the better they got. They worked well on our car and got us a new best 60ft last time out. True real world results with our car, HTH's
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833562
10/19/10 04:41 PM
10/19/10 04:41 PM
I'll try to get a pic up of my car launching, you can see the tire wad up very clearly. Mine worked best at 7.5 psi but I could probably run more at a better track, still the tire has yet to even turn a revolution on any launch at any track and I still have some adjusting to do on the four link.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833563
10/19/10 04:51 PM
10/19/10 04:51 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
HTH's
I need that same size but I didnt see it listed on the Toyo website. Did they quit making it?
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833564
10/19/10 06:38 PM
10/19/10 06:38 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Were at 13.5ish psi from our usual 12, (I'd have to check the journal). I think we could go more, the Caltracs hit the tyre hard and the car is heavy.
Toyo UK are still listing it http://www.toyo.co.uk/productdetail.php?identity=products&product_id=55 , I can't find a US site for Toyo's. I'd be dissapointed if they stopped making it (or them) definitely has the edge IMHO
Tyre comparisons for reference
M/T Sww 13.1 Trd 10.2 Dia 29.9 Circ 94
Toyo Sww 13.3 Trd 11.2 Dia 29.7 Circ 93.7 all in inches
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Tig] #833565
10/19/10 06:48 PM
10/19/10 06:48 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
This is all they list making.
24.0X4.5-15 In Stock BSW $141.00
25.0X4.5-15 In Stock BSW $135.00
25.0X9.0-15 In Stock BSW $158.00
26.0X4.5-15 In Stock BSW $138.00
26.0X9.0-15 In Stock BSW $162.00
27.5X4.5-15 In Stock BSW $151.00
28.0X9.0-15 In Stock BSW $177.00
29.0X9.0-15 In Stock BSW $177.00
30.0X9.0-15 In Stock BSW $187.00
32.0X14.5-15 Call BSW $261.00
33.0X16.0-15 In Stock BSW $285.00
33.0X17.0-15 In Stock BSW $292.00
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833566
10/19/10 06:56 PM
10/19/10 06:56 PM
OK, here it is
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Guitar Jones] #833567
10/19/10 07:36 PM
10/19/10 07:36 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
DaKuda, Toyo UK list these in addition to the list you have:
15W"
30.0x10.5 - 15W 11.2 29.7 93.3 13.3 29.3 10.0 8.0-10.0 14
33.0X10.5 - 15W * * * * * * * *
16W"
33.0X10.5 - 16W * * * * * * * *
16"
33.5X17.0 - 16 * * * * * * * *
34.0x17.0 - 16 17.0 34.4 108.0 20.4 45.2 16.0 15.0-16.0 6
Don't know why they aren't listed on the US site
Guitar Jones, We wadded the tyres pretty bad to begin with, just kept increasing the pressure, the car ran a better 60ft each time.
Looks like you could go more, seems like they take more pressure than the usual brands
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Guitar Jones] #833568
10/19/10 07:56 PM
10/19/10 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
OK, here it is
Put some air in them things
EDIT
Looks like you could use a anti roll bar also
Re: Toyo slicks and front race tires. Buy one get one free! [Re: DaKuda] #833569
10/19/10 08:52 PM
10/19/10 08:52 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Thanks!
Re: Toyo slicks and front race tires. Buy one get one free! [Re: Dart1031] #833570
10/19/10 10:25 PM
10/19/10 10:25 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
these aren't DOT fronts are they? what about the 27.5 on a Duster? 27.8in. and maybe a hair more on a 3.5in. rim would need trimming I think.
Re: Toyo slicks and front race tires. Buy one get one free! [Re: j.mcconnell] #833571
10/19/10 11:42 PM
10/19/10 11:42 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
What would you guys reccomend?
69 b-body 383 4-speed 4:10 gear
13.04 @110 with a street radial 285/70r15(spinning badly)(31" tall tire)
Now my current tire is a 275/60r15 they look a little small back there.(have not ran this size at track)28" tall
I have 8 in rims
should I run the 370070 (29.0x9.0x15)
or the 370280(30.0x09.0x15)
I will be buying one of these part numbers so keep it limited to these 2.
I'm not a die-hard racer,but would love to see my car run somewhere in the twelves.
I know that you should use the tallest tire you can get under there,but I felt that the 285/70r15 radials were too tall!
Thanks!
Page 1 of 3 1 2 3
