Toyo slicks and front race tires. Buy one get one free!
#833552
10/19/10 09:19 AM
10/19/10 09:19 AM
Posts: 1,015 Down South
DaKuda
Down South
Just wanted to make sure you guys have seen this. A guy here bought several pair of 32x14 and loves them. They say they are really good tires, just trying to get their name out there. They dont make a rear in my size so I bought two fronts. Got 2 27x4.5 fronts for $148. Best part is its unlimited to how many you buy! Great deal. Link: http://www.treadzone.com/files/news/pdf/Toyo_Proxes_Drag_Slicks_Promotion.pdf
Re: Toyo slicks and front race tires. Buy one get one free!
[Re: DaKuda]
#833553
10/19/10 09:23 AM
10/19/10 09:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
[Re: Dart1031]
#833555
10/19/10 09:54 AM
10/19/10 09:54 AM
DaKuda
Down South
"Limited to NHRA members only"
That means NOTHING. Im not an NHRA member. All they asked me for was my debit card number..
[Re: DaKuda]
#833556
10/19/10 10:36 AM
10/19/10 10:36 AM
Guitar Jones
I've been running their 14.5x32's on my Scamp for over a year and I really like them. I'm buying another set now even those these are not worn out yet.
[Re: Guitar Jones]
#833557
10/19/10 01:49 PM
10/19/10 01:49 PM
Posts: 2,924 A shed in England
Tig
A shed in England
FWIW we ran Hoosiers, M/T's for years. Had to buy Toyo's when we had difficulty buying the usual brands. Was a bit sceptical but I think they are a really good tyre, work well on our car and I'll use them again
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#833558
10/19/10 03:55 PM
10/19/10 03:55 PM
DaKuda
Down South
What size Toyo did you go with?
[Re: DaKuda]
#833559
10/19/10 04:11 PM
10/19/10 04:11 PM
Tig
A shed in England
30 x 10.5 W. Very similar in size to the 29.5 x 10.5 M/T 3062. "Tread" is a little wider and the tyre surprisingly took a little more pressure than we usually run. It was around 1 1/2 to 1 1/4 lb more if IIRC. Ran with tubes, still think it could take more pressure maybe upto 14lb. HTH's
[Re: Tig]
#833560
10/19/10 04:24 PM
10/19/10 04:24 PM
Guitar Jones
Toyo says the tires are designed to be ran without tubes.
[Re: Guitar Jones]
#833561
10/19/10 04:34 PM
10/19/10 04:34 PM
Tig
A shed in England
I did think that they are of a stiffer sidewall construction than Hoosiers or M/T and considered leaving the tubes out. At the track, we still had to run more pressure than I expected, even with the tubes. The more pressure we put in, the better they got. They worked well on our car and got us a new best 60ft last time out. True real world results with our car, HTH's
[Re: Tig]
#833562
10/19/10 04:41 PM
10/19/10 04:41 PM
Guitar Jones
I'll try to get a pic up of my car launching, you can see the tire wad up very clearly. Mine worked best at 7.5 psi but I could probably run more at a better track, still the tire has yet to even turn a revolution on any launch at any track and I still have some adjusting to do on the four link.
[Re: Tig]
#833563
10/19/10 04:51 PM
10/19/10 04:51 PM
DaKuda
Down South
I need that same size but I didnt see it listed on the Toyo website. Did they quit making it?
[Re: DaKuda]
#833564
10/19/10 06:38 PM
10/19/10 06:38 PM
Tig
A shed in England
Were at 13.5ish psi from our usual 12, (I'd have to check the journal). I think we could go more, the Caltracs hit the tyre hard and the car is heavy. Toyo UK are still listing it http://www.toyo.co.uk/productdetail.php?identity=products&product_id=55 , I can't find a US site for Toyo's. I'd be dissapointed if they stopped making it (or them) definitely has the edge IMHO Tyre comparisons for reference M/T Sww 13.1 Trd 10.2 Dia 29.9 Circ 94 Toyo Sww 13.3 Trd 11.2 Dia 29.7 Circ 93.7 all in inches
[Re: DaKuda]
#833566
10/19/10 06:56 PM
10/19/10 06:56 PM
Guitar Jones
OK, here it is
[Re: Guitar Jones]
#833567
10/19/10 07:36 PM
10/19/10 07:36 PM
Tig
A shed in England
DaKuda, Toyo UK list these in addition to the list you have: 15W" 30.0x10.5 - 15W 11.2 29.7 93.3 13.3 29.3 10.0 8.0-10.0 14 33.0X10.5 - 15W * * * * * * * * 16W" 33.0X10.5 - 16W * * * * * * * * 16" 33.5X17.0 - 16 * * * * * * * * 34.0x17.0 - 16 17.0 34.4 108.0 20.4 45.2 16.0 15.0-16.0 6 Don't know why they aren't listed on the US site Guitar Jones, We wadded the tyres pretty bad to begin with, just kept increasing the pressure, the car ran a better 60ft each time. Looks like you could go more, seems like they take more pressure than the usual brands
[Re: DaKuda]
#833569
10/19/10 08:52 PM
10/19/10 08:52 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
Thanks!
